Unique Field Value
Available with ArcGIS Pro Standard and Data Reviewer licenses.
Summary
The ArcGIS Data Reviewer Unique Field Value check finds rows in feature class attribute tables and stand-alone tables that contain nonunique values in a field or a list of fields that are editable. This can include point, line, or polygon feature classes.
Supported workflows
ArcGIS Data Reviewer checks support multiple methods for implementing automated review of data. The following table identifies the supported implementation methods for this check:
Workflow
Supported
Licensing
Validation attribute rule
Yes (ArcGIS Pro 2.9 and ArcGIS Enterprise 10.9.1 or later)
Constraint attribute rule
No
N/A
Run Data Checks
Yes (ArcGIS Pro 3.5 or later)
Available with a Data Reviewer license
Overview
The Unique Field Value check identifies recurring attribute values in the defined fields. Features or rows from the input data source are returned as errors when attribute values are not unique. You can configure this check on fields with Raster or Blob data types and on editable fields; it excludes noneditable fields, such as OBJECTID, GlobalID, editor tracking fields, and fields that have been configured as Read Only.
Industry scenarios
This check can be used in the following scenarios:
  • Indoor data management—Features, such as units, must contain unique identifiers to ensure that features in floor-aware maps are associated with their corresponding facility and level.
  • Tax parcel management—The record name must be unique to avoid creating records with the same name in legal plans or records of survey.
Attribute Rule syntax
The following table describes the validation attribute rule parameters:
Parameter
Required
Workflow
Subtype
No
The subtype or subtypes to which the rule is applied.
Validation
Attribute
No
A query that identifies the features to which the rule is applied.
Validation
Attributes to Compare
Yes
A list of editable fields in the input data source that evaluates unique field values.
To select all of the listed attributes, check the Select All check box. To select specific attributes, check the check box next to each attribute that you want to compare.
Validation
Name
Yes
A unique name for the rule.
Use this information to support data quality requirement traceability, automated reporting, and corrective workflows.
Validation
No
A description of the error you define when a noncompliant feature is found.
Use this information to provide guidance for corrective workflows.
Validation
Severity
No
The severity of the error assigned when a noncompliant feature is found.
This value indicates the importance of the error relative to other errors. Values range from 1 to 5, with 1 being the highest priority and 5 being the lowest.
Validation
Tags
No
The tag property of the rule.
This information is used in rule authoring and management workflows to support traceability and reporting of data quality requirements.
Validation
Run Data Checks syntax
The following table describes the Run Data Checks parameters:
Parameter
Required
Input Feature
Yes
The input feature layer that is evaluated by the rule.
You can disable a map selection or layer definition query using the toggle button that honors the selection or filter before evaluation.
Subtypes
No
Attribute Filter
No
Yes
Name
Yes
Use this information to support data quality requirement traceability.
Extent
Yes
  • Visible Extent—Evaluate the visible extent of the map.
  • Full Extent—Evaluate the full extent of the data.
Notes
  • If you configure a rule with multiple fields, the error result for the feature class displays each condition separated by a semicolon.
  • Features with null or invalid geometries are not evaluated by this check. Use the Check Geometry check to find invalid geometry features and correct them before using this check.
  • The Attribute and the Attributes to Compare filter parameters do not support the following field types: Big Integer, Date Only, Time Only, and Timestamp offset.
  • When this check is authored as a Run Data Check, Subtype Group Layers are not supported.
