Evaluate Z Values
Available with ArcGIS Pro Standard and Data Reviewer licenses.
Summary
The Evaluate Z Values check returns features with z-values that fall within specified parameters.
Supported workflows
ArcGIS Data Reviewer checks support multiple methods for implementing automated review of data. The following table identifies the supported implementation methods for this check:
Workflow
Supported
Licensing
Validation attribute rule
Yes (ArcGIS Pro 2.9 and ArcGIS Enterprise 10.9.1 or later)
Constraint attribute rule
No
N/A
Run Data Checks
Yes (ArcGIS Pro 3.5 or later)
Available with a Data Reviewer license
Overview
A z-value usually indicates the elevation of a feature in relation to the ground surface. If features from a feature class should be populated with relatively similar values for elevation, you can run the Evaluate Z Values check to ensure that the elevations are within an expected range of values. You can run the check on an entire feature class, a subtype, or a set of features selected using an SQL query. Features with z-values that fall within the specified range are returned.
Attribute Rule syntax
The following table describes the validation attribute rule parameters:
Parameter
Required
Workflow
Subtype
No
The subtype or subtypes to which the rule is applied.
Validation
Attribute
No
A query that identifies the features to which the rule is applied.
Validation
Elevation Value
Yes
The operation used to determine the threshold for z-values. Any features whose elevation values match those defined in the rule are returned as an error.
  • is equal to—The z-value is equal to the elevation value specified. For example, if the value is 10, features with a z-value of 10 are returned as results.
  • is not equal—The z-value is not equal to the elevation value specified. For example, if the value is 10, features with a z-value of 8, 12, or any other value that is not equal to 10 are returned as results.
  • is less than—The z-value is less than the elevation value specified. For example, if the value is 10, features with a z-value less than 10 are returned as results.
  • is less than or equal to—The z-value is equal to or less than the elevation value specified. For example, if the value is 10, features with a z-value of 10 or less are returned as results.
  • is greater than—The z-value is greater than the elevation value specified. For example, if the value is 10, features with a z-value greater than 10 are returned as results.
  • is greater than or equal to—The z-value is equal to or greater than the elevation value specified. For example, if the value is 10, features with a z-value of 10 or more are returned as results.
  • is between (including bounds)—The z-value is between or equal to the elevation value specified in the Lower Bound (minimum) and Upper Bound (maximum) text boxes. For example, if the lower bound is 1 and the upper bound is 10, features with a z-value of 1 through 10 are returned as results.
  • is between (excluding bounds)—The z-value is between the elevation value specified in the Lower Bound (minimum) and Upper Bound (maximum) text boxes. For example, if the lower bound is 1 and the upper bound is 10, features with a z-value greater than one and less than 10 are returned as results.
  • is not between (including bounds)—The z-value is not equal to or between the elevation value specified in the Lower Bound (minimum) and Upper Bound (maximum) text boxes. For example, if the lower bound is 1 and the upper bound is 10, features with a z-value less than 1 or greater than 10 are returned as results.
  • is not between (excluding bounds)—The z-value is equal to or not between the elevation value specified in the Lower Bound (minimum) and Upper Bound (maximum) text boxes. For example, if the lower bound is 1 and the upper bound is 10, features with a z-value of 1 or less or 10 or greater are returned as results.
More input is required if you choose an operator with upper and lower bounding values.
Validation
Name
Yes
A unique name for the rule.
Use this information to support data quality requirement traceability, automated reporting, and corrective workflows.
Validation
No
A description of the error you define when a noncompliant feature is found.
Use this information to provide guidance for corrective workflows.
Validation
Severity
Yes
The severity of the error assigned when a noncompliant feature is found.
This value indicates the importance of the error relative to other errors. Values range from 1 to 5, with 1 being the highest priority and 5 being the lowest.
Validation
Tags
No
The tag property of the rule.
This information is used in rule authoring and management workflows to support traceability and reporting of data quality requirements.
Validation
Run Data Checks syntax
The following table describes the Run Data Checks parameters:
Parameter
Required
Input Feature
Yes
The input feature layer that is evaluated by the rule.
You can disable a map selection or layer definition query using the toggle button that honors the selection or filter before evaluation.
Subtypes
No
Attribute Filter
No
Elevation Value
Yes
Name
Yes
Use this information to support data quality requirement traceability.
Extent
Yes
  • Visible Extent—Evaluate the visible extent of the map.
  • Full Extent—Evaluate the full extent of the data.
Notes
Keep the following in mind when using the check:
  • A vertical coordinate system must be defined for the feature class used with this check.
  • The Attribute filter parameter is limited to comparison (=, <>, >, <, >=, and <=) and logical (AND/OR, IN/NOT IN, LIKE/NOT LIKE, and IS NULL) operators.
  • The Attribute filter parameter does not support the following field types: Big Integer, Date Only, Time Only, and Timestamp Offset. If selected, the row header is marked in red and does not allow the rule to be saved.
  • The following conditions apply when this check is authored as a Run Data Check:
    • Subtype Group Layers are not supported.
    • Multipoint error results are supported.
