Evaluate Polygon Perimeter and Area
Available with ArcGIS Pro Standard and Data Reviewer licenses.
Summary
The Evaluate Polygon Perimeter and Area check finds polygon features based on the area or perimeter of the entire polygon or its individual parts or segments.
Supported workflows
ArcGIS Data Reviewer checks support multiple methods for implementing automated review of data. The following table identifies the supported implementation methods for this check:
Workflow
Supported
Licensing
Validation attribute rule
Yes (ArcGIS Pro 2.5 and ArcGIS Enterprise 10.8 or later)
Constraint attribute rule
Yes (ArcGIS Pro 2.4 or later)
Run Data Checks
Yes (ArcGIS Pro 3.5 or later)
Available with a Data Reviewer license
Overview
The Evaluate Polygon Perimeter and Area check identifies features that meet either area or perimeter conditions that are invalid. This can include an evaluation of the feature's entire geometry or its constituent parts or segments.
When configured as a constraint rule, an error notification is returned when a feature based on the specified range defined in the rule is created or modified.
When configured as a validation rule, an error is created during validation for each feature that contains an area or perimeter measurement within the specified range.
Industry scenarios
This check can be used in the following scenarios:
  • In facility mapping, certain types of structures, such as sheds, must have an area less than a specified size; otherwise, they must be coded with a different structure type.
  • In topographic mapping, features must have segment lengths greater than a specified value to maintain consistency in products generated from multiple data sources.
Attribute Rule syntax
The following table describes the validation and constraint attribute rule parameters:
Parameter
Required
Workflow
Subtype
No
The subtype or subtypes to which the rule is applied.
Constraint
Validation
Attribute
No
A query that identifies the features to which the rule is applied.
Validation
Evaluate
Yes
The geometric property of the feature evaluated by the check.
  • Area—Evaluates the area of the entire feature or its individual parts.
  • Perimeter—Evaluates the length of the entire feature or its individual parts or segments.
Constraint
Validation
Type
Yes
The method used when evaluating a feature's area or perimeter.
  • Polygons—Evaluates the area or perimeter of the entire polygon feature.
  • Parts—Evaluates the area or perimeter of individual parts of a polygon.
  • Segments—Evaluates the perimeter of the segments of a polygon.
Constraint
Validation
Search Goal
Yes
Error conditions evaluated by the rule. Any feature whose values match those defined in the rule are returned as an error.
  • Is equal to—The perimeter or area is equal to the number of units specified.
  • Is not equal to—The perimeter or area is not equal to the number of units specified.
  • Is greater than—The perimeter or area is greater than the number of units specified.
  • Is greater than or equal to—The perimeter or area is equal to or greater than the number of units specified.
  • Is less than—The perimeter or area is less than the number of units specified.
  • Is less than or equal to—The perimeter or area is equal to or less than the number of units specified.
  • Is between (including bounds)—The perimeter or area is between or equal to the number of units specified in the lower bound (minimum) and upper bound (maximum) values.
  • Is between (excluding bounds)—The perimeter or area is between the number of units specified in the lower bound (minimum) and upper bound (maximum) values.
  • Is not between (including bounds)—The perimeter or area is not equal to or between the number of units specified in the lower bound (minimum) and upper bound (maximum) values.
  • Is not between (excluding bounds)—The perimeter or area is equal to or not between the number of units specified in the lower bound (minimum) and upper bound (maximum) values.
More input is required if you choose an operator with upper and lower bounding values.
Constraint
Validation
Triggers
Yes
The editing events that trigger the rule to take effect.
  • Insert—Triggers the rule when a new feature is added.
  • Update—Triggers the rule when a feature is updated.
  • Delete—Triggers the rule when a feature is deleted.
Constraint
Name
Yes
A unique title or name for the rule.
Use this information to support data quality requirement traceability, automated reporting, and corrective workflows.
Constraint
Validation
No
A description of the error you define when a noncompliant feature is found.
Use this information to provide guidance for corrective workflows.
Constraint
Validation
Severity
No
The severity of the error assigned when a noncompliant feature is found.
This value indicates the importance of the error relative to other errors. Values range from 1 to 5, with 1 being the highest priority and 5 being the lowest.
Validation
Tags
No
The tag property of the rule.
This information is used in rule authoring and management workflows to support traceability and reporting of data quality requirements.
Constraint
Validation
Run Data Checks syntax
The following table describes the Run Data Checks parameters:
Parameter
Required
Input Feature
Yes
The input feature layer that is evaluated by the rule.
You can disable a map selection or layer definition query using the toggle button that honors the selection or filter before evaluation.
Subtypes
No
Attribute Filter
No
Evaluate
Yes
Type
Yes
Search Goal
Yes
Name
Yes
A unique name for the rule.
Use this information to support data quality requirement traceability.
Extent
Yes
  • Visible Extent—Evaluate the visible extent of the map.
  • Full Extent—Evaluate the full extent of the data.
Notes
Keep the following in mind when using the check:
  • The errors found by this check differ depending on whether the entire feature or its individual parts or segments are evaluated.
  • When this check is authored as an attribute (constraint) rule, support for geographic coordinate system-based datasets is limited to those using Web Mercator (WKID 3857) or WGS84 (WKID 4326).
  • The Attribute filter parameter is limited to comparison (=, <>, >, <, >=, and <=) and logical (AND/OR, IN/NOT IN, LIKE/NOT LIKE, and IS NULL) operators.
  • The Attribute filter parameter does not support the following field types: Big Integer, Date Only, Time Only, and Timestamp Offset. If selected, the row header is marked in red and does not allow the rule to be saved.
  • The following condition applies when this check is authored as a Run Data Check:
    • Subtype Group Layers are not supported.
