Evaluate Polyline Length
Available with ArcGIS Pro Standard and Data Reviewer licenses.
Summary
The Evaluate Polyline Length check finds polyline segments, parts, or features that have a length within a specified tolerance.
Supported workflows
ArcGIS Data Reviewer checks support multiple methods for implementing automated review of data. The following table identifies the supported implementation methods for this check:
Workflow |
Supported |
Licensing |
Validation attribute rule |
Yes (ArcGIS Pro 2.5 and ArcGIS Enterprise 10.8 or later) |
Available with ArcGIS Pro Standard and Data Reviewer licenses |
Constraint attribute rule |
Yes (ArcGIS Pro 2.4 or later) |
Run Data Checks |
Yes (ArcGIS Pro 3.5 or later) |
Available with a Data Reviewer license |
Overview
The Evaluate Polyline Length check identifies features that meet length conditions that are invalid. This can include an evaluation of the polyline's entire geometry or its individual parts or segments.
When configured as a constraint rule, an error notification is returned when a feature with a length measurement specified in the rule is created or modified.
When configured as a validation rule, an error is created during validation for each feature that contains a length measure within the specified range.
Attribute Rule syntax
The following table describes the validation and constraint attribute rule parameters:
Parameter |
Required |
Description |
Workflow |
Subtype |
No |
The subtype or subtypes to which the rule is applied. |
Constraint |
Validation |
Attribute |
No |
A query that identifies the features to which the rule is applied. |
Validation |
Type |
Yes |
The method used when evaluating a feature's length.
Constraint |
Validation |
Length |
Yes |
The query that is applied to the length of a feature geometry, its parts, or its segments. Any feature with length values that match those defined in the rule is returned as an error.
More input is required if you choose an operator with upper and lower bounding values. |
Constraint |
Validation |
Triggers |
Yes |
The editing events that trigger the rule to take effect.
Constraint |
Name |
Yes |
A unique name for the rule. Use this information to support data quality requirement traceability, automated reporting, and corrective workflows. |
Constraint |
Validation |
Severity |
No |
The severity of the error assigned when a noncompliant feature is found. This value indicates the importance of the error relative to other errors. Values range from 1 to 5, with 1 being the highest priority and 5 being the lowest. |
Validation |
Description |
No |
A description of the error you define when a noncompliant feature is found. Use this information to provide guidance for corrective workflows. |
Constraint |
Validation |
Tags |
No |
The tag property of the rule. This information is used in rule authoring and management workflows to support traceability and reporting of data quality requirements. |
Constraint |
Validation |
Run Data Checks syntax
The following table describes the Run Data Checks parameters:
Parameter |
Required |
Description |
Input Feature |
Yes |
The input feature layer that is evaluated by the rule. Note:You can disable a map selection or layer definition query using the toggle button that honors the selection or filter before evaluation. |
Subtypes |
No |
Attribute Filter |
No |
Type |
Yes |
Length |
Yes |
Name |
Yes |
A unique name for the rule. Use this information to support data quality requirement traceability. |
Extent |
Yes |
Notes
Keep the following in mind when using the check:
The errors found by this check differ depending on whether the entire feature or its individual parts or segments are evaluated.
When this check is authored as an attribute (constraint) rule, support for geographic coordinate system-based datasets is limited to those using Web Mercator (WKID 3857) or WGS84 (WKID 4326).
The Attribute filter parameter is limited to comparison (
=,<>,>,<,>=, and<=) and logical (AND/OR,IN/NOT IN,LIKE/NOT LIKE, andIS NULL) operators.The Attribute filter parameter does not support the following field types:
Big Integer,Date Only,Time Only, andTimestamp Offset. If selected, the row header is marked in red and does not allow the rule to be saved.The following condition applies when this check is authored as a Run Data Check:
- Subtype Group Layers are not supported.
