Find Dangles
Available with ArcGIS Pro Standard and Data Reviewer licenses.
Summary
The Find Dangles check finds polylines that have dangles within a specified tolerance.
Supported workflows
ArcGIS Data Reviewer checks support multiple methods for implementing automated review of data. The following table identifies the supported implementation methods for this check:
Workflow
Supported
Licensing
Validation attribute rule
Yes (ArcGIS Pro 2.9 and ArcGIS Enterprise 10.9.1 or later)
Constraint attribute rule
No
N/A
Run Data Checks
Yes (ArcGIS Pro 3.5 or later)
Available with a Data Reviewer license
Overview
The Find Dangles check identifies polyline features that have nodes within a defined tolerance but are not connected to other polyline or polygon features. Dangles can occur if data has been moved or a feature has been extracted incorrectly. The polyline features are compared with features in the same feature class or across other polyline or polygon feature classes. You can run the check on an entire feature class, a subtype, or a set of features selected using an SQL query.
Industry scenarios
This check can be used in the following scenarios:
  • In utility networks, you can use this check to find where pipes or wires are undershoots or overshoots and do not connect to the rest of the network. This can affect downstream and upstream tracing results.
  • In address management, it may be invalid for the street centerline feature class to have a street that is not connected to other streets. This check can find streets that need to be connected by setting a dangle tolerance.
Attribute Rule syntax
The following table describes the validation attribute rule parameters:
Parameter
Required
Workflow
Subtype
No
The subtype or subtypes to which the rule is applied.
Validation
Attribute
No
A query that identifies the features to which the rule is applied.
Validation
Dangle Tolerance
Yes
The minimum distance to search for polyline nodes that are not connected to other features. Polyline features with nodes that are within this distance but not connected to other polyline features are returned as an error. The value must be greater than the input data source's x,y tolerance.
The default is the data source's x,y tolerance. The default unit of measure is the input data source's horizontal spatial reference.
When the spatial reference of the feature class is geographic (GCS), the tolerance is converted from degrees to meters.
Validation
Additional Features to Compare
No
Additional polyline or polygon feature classes to include in the comparison. Added feature classes to compare must have the same datum as the input data source.
To select all of the listed features, check the Select All check box. To select specific features, check the check box next to each feature that you want to compare.
Validation
Name
Yes
A unique name for the rule.
Use this information to support data quality requirement traceability, automated reporting, and corrective workflows.
Validation
No
A description of the error you define when a noncompliant feature is found.
Use this information to provide guidance for corrective workflows.
Validation
Severity
No
The severity of the error assigned when a noncompliant feature is found.
This value indicates the importance of the error relative to other errors. Values range from 1 to 5, with 1 being the highest priority and 5 being the lowest.
Validation
Tags
No
The tag property of the rule.
This information is used in rule authoring and management workflows to support traceability and reporting of data quality requirements.
Validation
Run Data Checks syntax
The following table describes the Run Data Checks parameters:
Parameter
Required
Input Feature
Yes
The input feature layer that is evaluated by the rule.
You can disable a map selection or layer definition query using the toggle button that honors the selection or filter before evaluation.
Subtypes
No
Attribute Filter
No
Dangle Tolerance
Yes
No
Name
Yes
Use this information to support data quality requirement traceability.
Extent
Yes
  • Visible Extent—Evaluate the visible extent of the map.
  • Full Extent—Evaluate the full extent of the data.
Notes
Keep the following in mind when using the check:
  • When you configure two or more feature classes as more features to compare, and the feature class for which you configured the check connects with one feature class but not all feature classes, this is not considered a dangle. The following images show feature 1 in orange, feature 2 in gray, feature 3 in green, and the tolerance feature in blue. In image A, feature 1 does not connect to added features within the tolerance. This is considered a dangle with an undershoot. In image B, when two features' endpoints connect but feature 3 doesn't, this is an undershoot scenario. However, since feature 1 is connected to at least one of the features within the tolerance, this is not considered a dangle. To find connection errors with feature 3, you need to configure a check specifically for that feature.
    Dangle (with undershoot) Not a dangle (with undershoot)
  • When you configure two or more feature classes as additional features to compare, and the feature class for which you configured the check connects with one feature class but not all feature classes, this is not considered a dangle. The next images show feature 1 in orange, the added feature 2 in gray, feature 3 in green, and the tolerance feature in blue. In image A, the endpoint of feature 1 does not connect to any more features within the tolerance. This is considered a dangle with an overshoot. In image B, when two features endpoints connect but the third doesn't, this is an overshoot scenario . However, since feature 1 is connected to at least one of the features within the tolerance, this is not considered a dangle. To find connection errors with feature 2, you need to configure a check specifically for that feature.
    Dangle (with overshoot) Not a dangle (with overshoot)
  • When you configure a polygon as another feature to compare, if the line endpoint does not touch an edge or vertex of the polygon that is within the specified tolerance, this is considered a dangle. Image A shows that the line endpoint and the polygon are within the tolerance feature, shown in blue, but the line endpoint does not touch the polygon edge or vertex; this is considered a dangle and is returned as an error. Image B is not considered a dangle and is not returned as an error.
    Dangle Not a dangle
  • The Validation Status attribute values of both the input features and the data sources included in the Additional Features to Compare parameter are ignored during evaluation. For example, input polyline features with a validation status of 0 (No calculation required, no validation required, no error), 1 (No calculation required, no validation required, has error(s)), 4 (Calculation required, no validation required, no error), or 5 (Calculation required, no validation required, has error(s)) are still included during rule evaluation.
  • Data sources for the Additional Features to Compare parameter must include a global ID field.
  • Include the data source for the Additional Features to Compare parameter when creating map or project packages, and sharing web layers with the Validation capability enabled.
  • The Attribute filter parameter is limited to comparison (=, <>, >, <, >=, and <=) and logical (AND/OR, IN/NOT IN, LIKE/NOT LIKE, and IS NULL) operators.
  • The Attribute filter parameter does not support the following field types: Big Integer, Date Only, Time Only, and Timestamp Offset. If selected, the row header is marked in red and does not allow the rule to be saved.
  • The following conditions apply when this check is authored as a Run Data Check:
    • Subtype Group Layers are not supported.
    • Multipoint error results are supported.
