Polygon Gap is Sliver
Available with ArcGIS Pro Standard and Data Reviewer licenses.
Summary
The Polygon Gap is Sliver check finds gaps between polygon features that are equal to or below a specified thinness ratio.
Supported workflows
ArcGIS Data Reviewer checks support multiple methods for implementing automated review of data. The following table identifies the supported implementation methods for this check:
Workflow
Supported
Licensing
Validation attribute rule
Yes (ArcGIS Pro 2.9 and ArcGIS Enterprise 10.9.1 or later)
Constraint attribute rule
No
N/A
Run Data Checks
Yes (ArcGIS Pro 3.5 or later)
Available with a Data Reviewer license
Overview
The Polygon Gap is Sliver check finds gaps between polygon features that are slivers based on their shape and, optionally, size. Sliver gaps between polygon features often result from creating polygon features without proper snapping settings or from editing shared boundaries without topology.
When configured as a validation rule, an error is created for each feature that shares a boundary with a sliver gap.
Attribute Rule syntax
The following table describes the validation attribute rule parameters:
Parameter
Required
Workflow
Subtype
No
The subtype or subtypes to which the rule is applied.
Validation
Attribute
No
A query that identifies the features to which the rule is applied.
Validation
Features to Compare
Yes
Input features are returned as errors based on their relationship to the features from this data source.
Valid inputs are polygon features with a datum that matches the datum of the input features.
Validation
Filter
No
A query that identifies the features to include in the rule, from the data source specified in the Features to Compare parameter.
Validation
Thinness Ratio
Yes
The thinness ratio (T) between a gap’s area (A) and its perimeter (P) is calculated using the following equation:
\(T \space = \space 4π(A/P²)\)
A thinness ratio of 1 is a perfect circle, and a thinness ratio of 0 is a line.
Gaps between polygons with a thinness ratio less than this value are considered errors.
Validation
Maximum Area
No
The maximum area of a gap for it to be considered a sliver gap. Gaps between polygons that are below the thinness ratio and equal to or less than this value are considered errors.
Validation
Name
Yes
A unique name for the rule.
Use this information to support data quality requirement traceability, automated reporting, and corrective workflows.
Validation
No
A description of the error you define when a noncompliant feature is found.
Use this information to provide guidance for corrective workflows.
Validation
Severity
No
The severity of the error assigned when a noncompliant feature is found.
This value indicates the importance of the error relative to other errors. Values range from 1 to 5, with 1 being the highest priority and 5 being the lowest.
Validation
Tags
No
The tag property of the rule.
This information is used in rule authoring and management workflows to support traceability and reporting of data quality requirements.
Validation
Run Data Checks syntax
The following table describes the Run Data Checks parameters:
Parameter
Required
Input Feature
Yes
The input feature layer that is evaluated by the rule.
You can disable a map selection or layer definition query using the toggle button that honors the selection or filter before evaluation.
Subtypes
No
Attribute Filter
No
Features to Compare
Yes
Filter
No
Thinness Ratio
Yes
Maximum Area
No
Name
Yes
Use this information to support data quality requirement traceability.
Extent
Yes
  • Visible Extent—Evaluate the visible extent of the map.
  • Full Extent—Evaluate the full extent of the data.
Notes
Keep the following in mind when using the check:
  • The data sources of the input features and Features to Compare parameter must share a common datum.
    Learn more about spatial references
  • The Validation Status attribute values of both the input features and the data sources included in the Features to Compare parameter are ignored during evaluation. For example, input features with a validation status of 0 (No calculation required, no validation required, no error), 1 (No calculation required, no validation required, has error(s)), 4 (Calculation required, no validation required, no error), or 5 (Calculation required, no validation required, has error(s)) are still included during rule evaluation.
  • The Attribute and Filter parameters are limited to comparison (=, <>, >, <, >=, and <=) and logical (AND/OR, IN/NOT IN, LIKE/NOT LIKE, and IS NULL) operators.
  • Data sources for the Features to Compare parameter must include a global ID field.
  • Errors are returned for gaps that are greater than the x,y tolerance of the spatial reference.
  • Include the data source for the Features to Compare parameter when creating map or project packages and when sharing web layers with the Validation capability enabled.
  • The Attribute and the Features to Compare filter parameters do not support the following field types: Big Integer, Date Only, Time Only, and Timestamp Offset. If selected, the row header is marked in red and does not allow the rule to be saved.
  • The following condition applies when this check is authored as a Run Data Check:
    • Subtype Group Layers are not supported.
