Set security options
Security options allow you to control hyperlinks and clear the client certificate cache.
To set Security options, follow these steps:
Open the ArcGIS Pro settings page in one of the following ways:
From an open project, click the Project tab on the ribbon.
From the start page, click the Settings tab
In the list of side tabs, click Options.
On the Options dialog box, under Application, click Security.
Hyperlinks
Text fields in a table or pop-up, as well as text elements in a layout or report, automatically recognize and display a clickable link for text that meets a combination of URI schemes and file extensions. A recognized link appears blue and underlined in the field.
To control the list of URI schemes and file extensions used to recognize hyperlinks in a table, pop-up, layout, or report, complete the following steps:
To prevent all web links from being recognized, uncheck the Allow web links check box.
The default setting is checked.
Optionally, expand the Supported URI schemes option to manually modify the list.
To prevent all file links from being recognized, uncheck the Allow file links check box.
Optionally, expand the Supported file extensions option to manually modify the list.
Both lists include a menu button that provides the following options:
Reset
—Reset the list to the default settings.Load
—Load and replace the list from a file.Save
—Save the current list to a file.
The menu button is only available when an option is checked.
Client certificate cache
The client certificate cache stores information about certificates that you choose to remember when connecting to stand-alone servers that use public key infrastructure (PKI) authentication.
To delete the entire cache, click Clear Cache Now.
To delete the cache for specific servers, browse to C:\Users\<username>\AppData\Local\ESRI\ArcGISPro\Local Caches\ClientCertificatesV1 and delete individual files.
For more information, see Connect to an ArcGIS Server site.
