Introduction to ArcGIS Pro
Released version: ArcGIS Pro 3.7
ArcGIS Pro is a full-featured professional desktop GIS application from Esri. With ArcGIS Pro, you can explore, visualize, and analyze data; create 2D maps and 3D scenes; and share your work to ArcGIS Online or your ArcGIS Enterprise portal. The sections below introduce the sign-in process, the start page, ArcGIS Pro projects, and the user interface.
Sign in
The first time you use ArcGIS Pro, you sign in with the credentials of your ArcGIS Online or ArcGIS Enterprise organization. After that, you can sign in automatically.
ArcGIS Pro sign-in prompt
Once ArcGIS Pro starts, a sign-in menu appears at the top of the application window on the start page and in open projects. If you have more than one account, you can use the sign-in menu to change your active portal to access content or share items.
Sign-in menu
The sign-in menu as it appears in an open project.
Start page
By default, ArcGIS Pro opens to a start page. The start page has a Home tab , a Learning Resources tab , and a Settings tab .
Home tab
On the Home tab , you start new projects and open existing projects.
The Home tab of the ArcGIS Pro start page
Element Description
1 Click a default template, such as the Map template, to start a new project.
2 Click a recent project to open it. To open a project that is not in the list, click Open another project .
3 Click List or Tiles to display projects according to your preference.
4 Click a recent template to start a new project from a custom template. To start a new project from a template that's not in the list, click Start with another template .
Learning Resources
On the Learning Resources tab , you can find resources to help you develop skills, solve problems, and answer questions. Learning resources can also be accessed from a side tab on the Settings page . In an open project, click the Learning Resources button on the Help tab of the ribbon.
The Learning Resources tab of the ArcGIS Pro start page
Element Description
1 Quick-start tutorials introduce common ArcGIS Pro functionality and workflows.
2 You can access product documentation, learning materials, training, news, and the Esri Community site.
3 Tutorial series present learning materials related to an area of practice, such as mapping or analysis.
4 Resources are available to help ArcMap users learn ArcGIS Pro.
Settings
On the Settings tab , you configure and manage the application. In an open project, the settings can be accessed from the Project tab on the ribbon.
ArcGIS Pro settings
Tab Description
New Create a project.
Open Open an existing project.
Info View info for the current project.
Save Project Save the current project.
Save Project As Save a copy of the current project.
Portals Manage portal connections and set the active portal.
Licensing View license information, authorize ArcGIS Pro to work offline, and change the license type.
Options Configure project and application options.
Package Manager Manage environments and packages for Python, R, and system libraries.
Add-In Manager Install add-ins that provide custom functionality.
Help Open the online or offline help system.
About View information about your ArcGIS Pro version and update to the latest version.
Learning Resources Access quick-start tutorials, tutorial series, and other learning resources.
Exit Close the application.
Projects
In ArcGIS Pro, a project is a body of related work that may include maps, scenes, layouts, and connections to resources such as system folders and databases. Project files have the extension .aprx. By default, a project is stored in its own folder along with an associated file geodatabase and toolbox.
An ArcGIS Pro project
A project is shown with an active map and other open views. The ribbon is above the map. On either side of the map, the Contents and Catalog panes are open.
ArcGIS Pro user interface
The main parts of the ArcGIS Pro interface are the ribbon, views, and panes. The Introducing ArcGIS Pro quick-start tutorial helps you explore the user interface.
Ribbon
A horizontal ribbon at the top of the application window organizes functionality in a series of tabs. Some tabs, called core tabs, are either always present or present when a certain type of view is active. For example, the Help tab is always present. The Map tab is present whenever a map view is active.
Other tabs, called contextual tabs, are present when the application is in a particular state, such as when a certain type of layer or a layer with specific properties is selected in a map. For example, when you select a feature layer in the Contents pane of a map, the Feature Layer, Labeling, and Data contextual tabs appear. Contextual tabs appear on a white background.
ArcGIS Pro ribbon
Element Description
1 The Quick Access Toolbar has commonly used commands.
2 Click the drop-down arrow next to the project name to see where the project is stored and its last modification date and time.
3 Command search helps you find and run commands.
4 Core tabs—such as the Help tab—organize functionality. When a tab is selected, its associated tools and buttons appear on the ribbon.
5 Contextual tabs—such as the Feature Layer, Labeling, and Data tabs—appear when the application is in a state appropriate for their use.
6 Groups organize related commands on a ribbon tab.
7 Buttons and tools run commands. For example, the Learning Resources button accesses learning resources on the settings page.
8 Click a dialog box launcher to open a dialog box or a pane related to items in a group.
9 Click Ribbon Display Options to choose between the classic ribbon or a simplified ribbon. You can also collapse the ribbon and show its tabs only.
Views
Views are windows for displaying and working with representations of your data, such as maps, scenes, layouts, tables, charts, reports, and the catalog. Many views can be open in a project, but you can only select and work with one at a time. The selected view is called the active view.
You make a view active by clicking the tab at the top of the view window. When a view is active, its tab is blue. You can drag the active view by its tab to a different position in the ArcGIS Pro window or outside the window. Ribbon tabs and commands may change according to the type of view that is active.
An active map view
In this example, the active view is a map named Christchurch Urban Area. Views representing another map, a layout, and a report are open in the project.
Panes
A pane can display the contents of a view (the Contents pane), the items in your project or active portal (the Catalog pane), or commands and settings for an area of functionality (the Symbology pane, Geoprocessing pane, Create Features pane, and so on).
The Contents pane of a map and the Catalog pane
Panes provide functionality that may not be available on the ribbon. They organize functionality using rows of text tabs and graphical tabs. Some panes have multiple pages.
Symbology pane with marked pane controls
Element Description
1 Some panes have multiple pages that you navigate with the Back button .
2 Text-based primary tabs, such as Gallery and Properties, organize functionality.
3 Graphical secondary tabs partition the functionality of a primary tab.
4 Expanders are small arrows that you click to show or hide settings.
5 The Menu button has additional commands.
6 Handles allow you to resize areas of a pane by dragging.
The Contents and Catalog panes are usually open in a project. Other panes appear in response to commands or actions. For example, when you click Locate on the Map tab of the ribbon, the Locate pane appears.
You can close panes or leave them open. If a pane is open when you close ArcGIS Pro, it is open when you restart the application. You can manage pane sets on the View tab of the ribbon.
When multiple panes are open, they can be stacked on top of each other. Icons appear on stacked panes to help you identify them. You can click a drop-down arrow to display the full name of each pane.
Overflow menu for panes
Arrange the user interface
You can arrange the elements of the user interface in various ways:
  • Drag panes and views to docking targets.
  • Stack panes and views on top of one another.
  • Float panes and views above or away from the application window (including on a different monitor).
  • Minimize floating views.
  • Divide view space into vertical or horizontal tab groups to display more views.
ArcGIS Pro user interface with customizations
Element Action Method
1 Collapse the ribbon and show ribbon tabs only. Press Ctrl+F1.
2 Scroll back and forth among multiple open views stacked in the same window. Click the Scroll Forward and Scroll Backward buttons or scroll the mouse wheel.
This functionality is available when the number of open views overflows the active view area.
3 Hide a pane to minimize it when not in use Click Auto-Hide in the pane's title bar. Alternatively, press Alt+Minus Sign for options.
4 Dock a view. Drag a view by its tab and drop it on one of the docking targets that appear. Alternatively, right-click the view tab of a floating view or press Alt+Hyphen for options.
5 Make a new tab group to divide view space. Right-click a view tab or press Alt+Hyphen for options.
6 Float a view. Drag a view by its tab and drop it away from docking targets. Alternatively, right-click the view tab or press Alt+Hyphen for options.
7 Minimize a floating view. Click the minimize button on the view. To restore the view, hover over the ArcGIS Pro icon in the Windows taskbar and click the view.
8 Stack panes to increase the space available for views. Drag a pane and dock it on top of another pane so they appear as tabs within a single window.
