Customize the ribbon options
You can customize the ArcGIS Pro ribbon by creating tabs and choosing which commands appear on them. You can also add new groups and commands to existing tabs.
Follow these steps to open the Customize the Ribbon options:
  1. Open the ArcGIS Pro settings page in one of the following ways:
    • From an open project, click the Project tab on the ribbon.
    • From the start page, click the Settings tab .
  2. In the list of side tabs, click Options.
  3. On the Options dialog box menu, under Application, click Customize the Ribbon.
    Customize the Ribbon tab on the Options dialog box
    Tip:
    You can also open the Customize the Ribbon options in the following ways:
    • Click the Quick Access Toolbar drop-down arrow and click Customize the Ribbon.
    • Right-click any ribbon tab or command and click Customize the Ribbon.
    • Click the Help tab on the ribbon. In the Customize group, click Ribbon .
Add tabs, groups, and commands to the ribbon
You can organize functionality by adding commands to new groups on existing ribbon tabs or by adding new tabs.
Add groups and commands
The following video shows you how to add groups and commands to existing ribbon tabs.
This video was created with ArcGIS Pro 3.7.
One way to customize the ribbon is to add a new group of commands to an existing tab.
  1. Open the Customize the Ribbon options.
  2. In the scrolling window on the right, representing ribbon tabs and groups, optionally click the Currently Visible Tabs drop-down arrow and choose All Tabs to add a group to a tab that is not currently visible.
  3. Browse to the tab to which you want to add a group.
    Tip:
    You can search for a visible tab or group using the search box under Select ribbon tab or group to customize.
  4. Select the tab. Optionally, expand the tab to see its groups.
  5. Click New Group.
    A selected tab with the New Group button indicated
    The Table contextual tab is selected. This tab appears on the ribbon when a table view is active.
    A new group named New Group (Custom) is added under the other groups on the tab.
  6. With New Group (Custom) selected, click Rename.
  7. On the Rename dialog box, change the display name and click OK.
  8. In the Select command(s) to add drop-down list, accept the default All Commands option or click the drop-down arrow and choose a different option:
    • Popular Commands—Commands that are regularly used in ArcGIS Pro.
    • Currently Visible Tabs—Only commands from the tabs currently visible in ArcGIS Pro are in the list of commands.
    • All Tabs—Commands from all tabs are included in the list.
    • Popular Geoprocessing Tools—Geoprocessing tools that are regularly used in ArcGIS Pro.
    • All Geoprocessing Tools—All geoprocessing tools that are available in ArcGIS Pro.
    Tip:
    A search box at the top of the list can help you find commands or tools.
  9. In the scrolling window of commands, browse to or search for the command you want to add.
    Tip:
    Widen the Options dialog box to see the full command names. Hover over a command to see a description of its behavior.
  10. Select a command and click Add.
    Find and Replace command added to a custom group
    Tip:
    Use the arrow buttons on the right side of the dialog box to change the order of groups on a tab or the order of commands in a custom group. You cannot change the order of commands in built-in groups.
  11. Click OK.
  12. Return to your project or open a project. On the ribbon, click the tab to which you added the new group.
    The group and its command or commands appear on the tab.
    Ribbon showing a custom group on the Table contextual tab.
Add a new tab
The following video shows you how to add a new tab to the ribbon.
You can add a new tab to the ribbon to organize commands that are not grouped on the ArcGIS Pro interface by default.
  2. Under the scrolling window on the right, representing ribbon tabs and groups, click the New Tab drop-down arrow and click New Tab.
    In the window, a new tab and new group are added at the bottom of the Main Tabs heading.
    New tab added to the list of ribbon tabs
    Tip:
    Moving the new tab to a different position is not recommended because it may not appear in the expected position in all situations.
  3. Click New Tab (Custom) to select it and click Rename.
  4. On the Rename dialog box, change the display name and click OK.
  5. Under the new tab, click New Group (Custom) to select it. Click Rename and rename the new group. Click OK.
  6. Optionally, select the new tab and add more groups. When you're finished, select a group to which to add commands.
  7. In the Select command(s) to add drop-down list, accept the All Commands setting or click the drop-down arrow and make a different choice.
  8. In the scrolling window of commands, browse to or search for a command. Select the command and click Add.
  9. Optionally, add more commands to the group. When you're finished, click OK.
  10. Return to your project or open a project to see the customization.
    Custom tab and commands on the ribbon
    A new tab named Metadata is added to the ribbon. It has one group and five commands.
    On the ribbon, the new tab appears to the right of the core Help tab by default.
Add a new contextual tab
Contextual tabs appear on the ribbon when the application is in a particular state. For example, when an attribute table is the active view, a Table contextual tab appears. When you add a custom contextual tab, it must appear together with an existing contextual tab.
The following video shows you how to add a new contextual tab to the ribbon.
  2. Click the Select ribbon tab or group to customize drop-down arrow and choose All Tabs.
  3. In the list below the drop-down arrow, scroll down past the tabs listed under Main Tabs to the contextual tab headings.
  4. Under a heading, click a contextual tab with which your new tab will be grouped.
    For example, to add a contextual tab that appears next to the Time contextual tab when a map view is active, scroll to the Map heading and click the Time tab.
    The Time contextual tab appears on the ribbon when the time property is enabled on a map layer.
  5. Click New Tab and click New Tab with Context.
    New contextual tab added to the list of ribbon tabs
    In the window, a new tab and new group are added under the contextual tab.
  6. Click New Tab (Custom) to select it and click Rename.
  8. Under the new tab, click New Group (Custom) to select it. Click Rename and rename the new group. Click OK.
  9. Optionally, select the new tab and add more groups. When you're finished, select a group to which to add commands.
  10. In the Select command(s) to add drop-down list, accept the All Commands setting or click the drop-down arrow and make a different choice.
  11. In the scrolling window of commands, browse to or search for a command. Select the command and click Add.
  12. Optionally, add more commands to the group.
    Custom contextual tab with a group that contains two geoprocessing tools
    Convert Temporal Field and Convert Time Zone are geoprocessing tools available in the All Geoprocessing Tools list.
  13. When you're finished, click OK.
  14. Return to your project or open a project to see the customization.
    Custom contextual tab on the ribbon
    To see the customization, you must create the conditions under which the contextual tab appears. In this example, the time property must be enabled on a map layer.
Search for commands using command IDs
Some commands have the same or similar names but work in different contexts. For example, there are different commands named Zoom Full Extent for map views, metadata previews, presentations, and network diagrams. When you search for commands in the Customize the Ribbon options, it may be hard to know which one is right for your purpose. However, every command has a unique ID that can be displayed on the user interface. You can use the command ID to confirm that you are adding the command you need to a custom group.
The following video shows you how to copy a command ID and use it to search for a command.
  2. Check the Show command IDs on ScreenTips check box.
  3. Click OK.
  4. Return to your project or open a project. Hover over a command on the ribbon to display its ScreenTip.
    Command ID for the Full Extent command on the Map tab
  5. Right-click the command and click Copy Command ID.
    You can copy the command ID of a ribbon command whether or not command IDs are shown. You can view—but not copy—the command IDs of context menu commands.
  6. Open the Customize the Ribbon options.
  7. On the Select command(s) to add drop-down list, leave All Commands selected.
  8. Right-click in the search box and click Paste.
    The command is found and can be added to a custom group.
  9. Optionally, uncheck the Show command IDs on ScreenTips check box.
  10. Click OK.
Remove commands, groups, and tabs from the ribbon
You can remove custom commands, groups, or tabs that you have added to the ribbon. You cannot remove built-in tabs. You can also hide built-in and custom tabs.
Remove custom commands, groups, and tabs
To remove custom commands, groups, and tabs, complete the following steps:
  2. In the scrolling window on the right (ribbon tabs and groups), browse to and select a custom tab or group, or select a command that you added to a custom group.
  3. Click Remove. Alternatively, right-click the selected item and click Remove.
    Custom contextual tab selected and Remove button indicated
    In this example, a custom contextual tab is removed.
    Removing a tab removes its groups and their commands. Removing a group removes its commands.
  4. Click OK.
Hide tabs
You can hide built-in and custom tabs to simplify the user interface. Hidden tabs are not shown on the ribbon but are not removed from the Customize the Ribbon options.
  2. In the scrolling window on the right (ribbon tabs and groups), uncheck the check boxes next to any tabs that you want to hide.
    Tip:
    If the tab you want to hide is not listed, click the Currently Visible Tabs drop-down arrow and choose All Tabs.
  3. Click OK.
    The tabs no longer appear on the ribbon. To show them again, open the Customize the Ribbon options and check their check boxes.
Export and import customizations
Customizations include changes to the ribbon, Quick Access Toolbar, keyboard shortcuts, and pane sets.
The following video shows you how to export and import customizations.
Export customizations
You can export customizations to a file to use on different computers or to share.
  2. Click Import/Export and click Export customizations.
    The Export customizations option is disabled if there are no customizations or if you have not yet saved customizations by clicking OK on the Options dialog box.
  3. On the browse dialog box, browse to the folder where you want to save the file.
  4. In the Name text box, type a name for the file.
  5. Click Save.
    The customization file is saved with the .proExportedUI file extension.
Import customizations
You can import customizations from a .proExportedUI file.
  2. Click Import/Export and click Import customizations.
  3. On the browse dialog box, browse to the folder that contains the customization file. Select the file and click OK.
    A confirmation message appears.
  4. On the message dialog box, choose an option:
    • Click Yes to import the customization file. Any existing customizations are overwritten.
    • Click No to cancel the operation.
  5. Click OK on the Options dialog box.
    The customizations specified in the file are applied.
    If you click Cancel on the Options dialog box, this also cancels the operation. Customizations are not imported.
Reset customizations
You can reset customizations for a selected ribbon tab. You can also reset all customizations to the ribbon and Quick Access Toolbar.
Reset a selected item
You can reset customizations to a built-in core or contextual ribbon tab.
  2. In the scrolling window on the right (ribbon tabs and groups), browse to a built-in tab that contains a custom group and select the tab.
    You can remove a custom tab, but not reset it.
  3. Click the Reset drop-down arrow and click Reset Selected Item.
    Alternatively, right-click the selected item and click Reset.
    Selected tab containing a custom group with the Reset Selected Item command highlighted
    The Find (Custom) group is removed from the Table contextual tab.
  4. Click OK.
    All customizations are removed from the selected tab. Customizations to other tabs are not affected.
Reset all
You can reset all customizations to the ribbon and Quick Access Toolbar.
  2. Click the Reset drop-down arrow and click Reset All.
  3. Click OK.
    The ribbon and Quick Access Toolbar are reset to their default states. Customizations to keyboard shortcuts and pane sets are not reset.
Configure keyboard shortcuts
A keyboard shortcut runs a command with a key or keystroke combination. ArcGIS Pro has many default shortcuts that you can modify. You can also create shortcuts for commands that don't have them.
You can add and modify shortcuts from the Customize the Ribbon options; however, the recommended practice is to work with keyboard shortcuts directly on the Keyboard Shortcuts dialog box.
  2. In the commands window, browse to or search for a command for which you want to add or modify a shortcut. Select the command.
  3. Under the list of commands, click Keyboard Shortcuts.
    The Keyboard Shortcuts dialog box appears. The shortcuts group for the active view is expanded. If the command does not support a shortcut, an error message appears at the top of the Keyboard Shortcuts dialog box.
    An appropriate type of view must be active in the project. For example, if you want to modify the shortcut for the Locate command , make sure a map view is active because the Locate command operates on maps. Similarly, if you add a shortcut for a command that doesn't currently have one, make sure a view is active in which the command works.
  4. On the Keyboard Shortcuts dialog box, specify a shortcut for a new command or modify an existing shortcut, as appropriate.
  5. Click Save.
  6. Click OK on the Options dialog box.
