ArcGIS Pro keyboard shortcuts
ArcGIS Pro keyboard shortcuts help you run user interface commands more quickly. Open a PDF of all default ArcGIS Pro shortcuts for any of the following languages:
You can customize keyboard shortcuts by changing the keystrokes associated with commands, adding new shortcuts, or removing shortcuts you don't need.
If you use a keyboard exclusively with the application, see Use ArcGIS Pro with a keyboard for keyboard shortcuts related to navigating the user interface.
Global keyboard shortcuts
The following default keyboard shortcuts are available in most or all active states of ArcGIS Pro:
Keyboard shortcut |
Action |
Ctrl+O |
Open a project. |
Ctrl+N |
Create a project. |
Ctrl+S |
Save the project. |
Ctrl+M |
Open a new map. |
F1 |
Open the help system to the default home page or context-sensitive help for a tool. |
Ctrl+F1 |
Show or hide the ribbon. |
F12 |
Open the Keyboard Shortcuts dialog box. |
Ctrl+Z |
Undo a change. |
Ctrl+Y or Ctrl+Shift+Z |
Redo a change. |
Ctrl+C |
Copy the selected item to the clipboard. |
Ctrl+X |
Cut the selected item. |
Ctrl+V |
Paste the selected item from the clipboard. |
Delete |
Delete the selected item. |
Ctrl+Alt+P |
Copy the path of the selected item to the clipboard. |
Ctrl+P |
Open the Print pane to print a map or layout. |
Ctrl+E |
Open the Export pane to export a map, layout, or report. |
Alt+L |
Open the Sign-In Status menu. |
Alt+W |
Open the Notifications pane. |
Alt+Q |
Search for a command. |
Ctrl+Alt+M |
Open Diagnostic Monitor. |
Ctrl+G |
Group the selected elements. |
Ctrl+Shift+G |
Ungroup the selected group. |
Other keyboard shortcuts
You can view default shortcuts for different parts of the application in the following topics. This is not a complete list of available keyboard shortcuts.
