Customize ArcGIS Pro with geoprocessing tools
You can save a custom set of geoprocessing tools in your user profile and in your projects for easier access. You can customize ArcGIS Pro with both ArcGIS system tools and custom tools that you've built or that others have shared with you.
You can also configure the ribbon or Quick Access Toolbar with specific geoprocessing tools. Customization of the ribbon and Quick Access Toolbar is saved in your user profile and applies to all the projects you use on your machine.
You can configure the following with custom sets of geoprocessing tools:
The Analysis Tools gallery
The Favorites tab in the Geoprocessing pane
Project toolboxes
Any ribbon tab, including existing ribbon tabs and new custom ribbon tabs
The Quick Access Toolbar
You can add geoprocessing tools to the Tools gallery on the Analysis ribbon tab.
To add a tool to the gallery, right-click a tool in the Geoprocessing pane and select Add To Analysis Gallery. Additionally, you can expand the gallery and select Customize to modify the groups and tools contained in the gallery.
Favorites
You can add and remove tools from the Favorites tab of the Geoprocessing pane. The Favorites tab lists the following tool favorites:
My Favorites—Tools that are recorded in your user profile and are listed regardless of the open project.
Project Favorites—Tools that are specific to the open project. When you create a project, several commonly used tools are included by default.
To add a tool to one of the favorites lists, right-click a tool in the Geoprocessing pane or Catalog pane and select Add To My Favorites or Add To Project Favorites. A tool can be in both favorites lists. To remove a tool from a list, right-click the tool in the list and select Remove.
Project toolboxes
You can add a toolbox containing tools for a project to the Toolboxes section of the Project tab, which is a shortcut to the toolbox referenced in the project.
To add a toolbox to a project, right-click a toolbox in a folder or database connection and select Add To Project. You can also click Project > Toolbox > Add Toolbox on the Insert ribbon tab or right-click the Toolboxes node of the Project tab and select Add Toolbox.
You can add toolboxes to the Catalog pane's Favorites tab to provide a shortcut to the toolbox regardless of the open project. To add a toolbox as a favorite, right-click a toolbox in a folder or database connection and select Add To Favorites
Customize the ribbon or Quick Access Toolbar
You can add geoprocessing tools to any ribbon tab and to the Quick Access Toolbar. You can customize these locations with ArcGIS system tools as well as custom model and script tools that have been added to a project. This customization is stored in your user profile and applies to any project you open.
Add a tool to the ribbon
To add a tool to the ribbon, complete the following steps:
Click Project > Options > Customize the Ribbon.
Under Choose commands from, select Popular Geoprocessing Tools or All Geoprocessing Tools.
Select the tool to add, or type in the search bar and select the tool from the search results list.
Select the ribbon tab and group where you want to add the selected tool from Tabs list.
You cannot add geoprocessing tools to a built-in ribbon tab groups, only to custom groups on those tabs. Use the New Tab or New Group buttons to create a location on a new or existing ribbon tab to add geoprocessing tools.
Click the Add button.
Add a tool to the Quick Access Toolbar
To add a tool to the Quick Access Toolbar, complete the following steps:
Click Project > Options > Quick Access Toolbar.
