Set time properties on data
To work with time-aware content, you must configure the layer's temporal properties to indicate where the data exists in time. This configuration can be based on attribute fields in the data, such as the date and time of earthquakes; set to a fixed extent for the entire layer, such as an aerial image with an effective lifespan of three months; or set the starting time for a simulation layer.
For data that contains temporal values, the time properties available for the layer vary depending on the dataset. For feature classes, stand-alone tables, catalog datasets, mosaic datasets, and netCDF feature layers, you can specify one field (time field) or two fields (a start time field and, optionally, an end time field). However, netCDF layers also allow you to specify a time dimension, which is the only time option for netCDF raster layers. For data that includes both date and time information, you can optionally specify a time zone for the layer.
Set time properties using attribute fields
To set time properties based on attribute fields, complete the following steps:
Double-click the temporal dataset in the Contents pane to open the Layer Properties dialog box.
On the Time tab, under Filter using time, choose the Filter layer content based on attribute values option. Choose from one of the following options:
Each feature has a single time field
For Layer Time based on a single field, set Time Field to the field that contains the time information.
Use this option if the time stamps are stored in a single attribute field. In this case, the feature exists at an instant in time.
Features with null values in data with a single time field are not seen when the time slider is played, as they cannot fall within a time span.
Each feature has a start and end time field
For Layer Time based on values stored in two fields, set Start Time Field and End Time Field to the corresponding fields that contain the start and end times. In this case, the feature exists for a certain duration in time.
Setting the end time field value is also useful if the time steps in the data are irregularly spaced. Learn more about irregularly spaced data.
When using either the DateOnly or TimestampOffset field to define durations in time, the same field type must be used for both the start and end time fields.
Layer has time as a dimension
For Layer Time based on a time dimension, set Time Dimension to the appropriate dimension.
Use this option if time is a dimension in the multidimensional dataset. This option is only available for netCDF layers.
If a text field is used to define the time field, the Time Format option appears.
Manually select the corresponding format from the drop-down gallery.
For the Time Extent property, by default, the time extent of the data is calculated as soon as you select a field.
If the data is large, it is possible that only a sampling of the data is used to determine the time extent. In this case, a warning icon appears next to the Calculate button. Hover over the warning icon to read the message.
To calculate the full time extent using all the rows in the table, click Calculate. Alternatively, manually enter the time extent for the layer.
If the time extent is empty, it likely means that the time field did not contain any valid time stamps. If you are expecting the field to contain valid time stamps, investigate the data and, specifically for string or numeric fields, verify that the time stamps are stored in one of the supported time formats.
Optionally, if the data includes continuous updates outside the application, such as current vehicle positions or weather data, check the Data is a live feed check box.
When this is set, an additional Live mode control is available on the time slider for automatically progressing the map's time extent with your system clock. When live mode is enabled, the layer is refreshed using the refresh rate set on the General page.
This option is not available for stand-alone tables.
Set the Time Interval property for the layer.
The time step interval can be used to configure the map's time slider and define the offset of each step. Tick marks appear along the time slider when using the layer time step option. Choose from one of the following options:
No predefined time interval
This is the default. The time slider does not step based on the layer properties but instead uses a configuration set in the Step group on the Time tab.
View using a regular time interval
Use this option if the data was captured at regular intervals, such as hour temperature readings. Set the value and time unit. The time slider for the map can use this layer-defined property to step directly to each time value by choosing the Layer option in the Step group on the Time tab.
View using unique times within the data
Use this option if the data was captured at irregular intervals, such as earthquakes or power outages. The time slider for the map can use this layer-defined property to step directly to each unique time value by choosing the Layer option in the Step group on the Time tab. This option is only available if there are fewer than 1,000 unique time values in the layer. You can use a definition query to filter larger datasets to this limit, as needed.
Optionally, set a Time Zone option for the layer.
Time Zone allows you to view temporal content so it is aligned with other time-aware elements, such as the scene's lighting model, as well as mix together content from different time zones. The values from a time-aware layer are adjusted from their own time zone to the map's time zone.
Optionally, choose the format used when time zones are displayed. Three choices are available:
IANA—Time zones are displayed using Internet Assigned Numbers Authority (IANA) extended names including both standard and daylight offsets.
IANA (abbreviated)—Time zones are displayed using Internet Assigned Numbers Authority (IANA) location names including only the standard offsets.
Microsoft Windows—Time zones are displayed using the Microsoft Windows operating system names. This is the default.
This property is read-only for layers that use a DateOnly or a TimestampOffset field. For DateOnly data, content is filtered solely on the date portion of the time slider's temporal extent, treating the layer as though it has no time zone. For TimestampOffset data, the temporal offset to UTC is stored in each value, so there is no benefit to defining an additional time zone for the whole layer.
This property is also read-only for web feature layers. Time zone values are also displayed in the attribute table as a tooltip when you hover over the column header, as well as on any calendar control when editing the value.
Learn more about editing map or feature service settings, including time zone
A web feature layer refers to a feature layer from a map or feature service.
Optionally, check Adjust for Daylight Saving to view the data in daylight saving time, when applicable, or uncheck to always show it in standard time.
Optionally, check Time zone applies to all temporal fields to apply the time zone to all temporal fields within the layer.
This option is enabled by default.
Optionally, set a Time Offset value for the data.
This allows you to align and visualize multiple temporal datasets through time.
Click OK to apply the changes and close the Layer Properties dialog box.
When you are finished working with time, you can disable time for the layer by reopening the Layer Properties dialog box and selecting the No time - content is always shown option.
Set time properties using a fixed time extent
To set time properties for an entire layer to a fixed time extent, complete the following steps:
Double-click the layer in the Contents pane to open the Layer Properties dialog box.
Click Time, and under the Visibility using time heading, check the Show the layer when the map is within a fixed time extent option.
Provide a start and end date value for when the layer should be visible.
The values can include a time component.
Optionally, set a Time Zone for the layer.
This allows you to view temporal content so it is aligned with other time-aware elements, such as the scene's lighting model, as well as mix content from different time zones. When using the time slider to filter content, the map's time extent and time zone are converted to time values in the layer's time zone. You can additionally check Adjust for Daylight Saving to view the data in daylight saving time, when applicable, or uncheck to always show it in standard time.
Optionally, set a Time Offset value for the layer.
Using a time offset works best when the temporal datasets you are trying to visualize or compare side by side do not overlap.
The fixed time extent layer property is not supported for web layers. An analyzer warning appears when sharing a web map or web layer that uses this setting.
Set time properties for feature service layers
The editing of time properties for a feature service is limited. Only the time extent can be modified. This is helpful when a feature service is continuously updating and you wish to only view a specific time frame. Alternatively, time can be disabled to view all features.
Update a feature service time extent
To edit the time extent of a feature service, complete the following steps:
On the Time tab, under Filter using time, update the Time Extent property.
If the data is large, it is possible that only a sample of the data is used to determine the time extent. In this case, a warning icon appears next to the Calculate button. Hover over the warning icon to read the message.
Disable time on a feature service
When you are finished working with time, You can disable time for the feature service layer by opening the Layer Properties dialog box and selecting the No time - content is always shown option.
Set time properties for simulation layers
To set time properties for a simulation layer, complete the following steps:
Double-click the simulation layer in the Contents pane to open the Layer Properties dialog box.
On the Time tab, under Filter using time, choose the The simulation layer begins at a specific time option.
Set Layer Time to Set a starting time for a simulation, the only available option.
For the Time Extent property, use the calendar button
or manually type a new extent value.By default, the closest whole hour that has past is provided.
Set the Time Interval property to View using the simulation layer cache, the only available option.
Optionally, set a Time Zone option for the layer. Optionally, check Adjust for Daylight Saving to view the data in daylight saving time, when applicable, or uncheck to always show it in standard time.
Time Zone allows you to view temporal content so it is aligned with other time-aware elements, such as the scene's lighting model, as well as mix content from different time zones. The values from a time-aware layer are adjusted from their own time zone to the map's time zone.
The Time zone applies to all temporal fields option is not available for simulation layers.
Set time zone without additional time properties
A time zone can be defined for a layer without setting any additional time properties. This option provides a reference time zone for any temporal fields in the layer when map time is used. To only set the time zone, complete the following steps:
Click Time and under the Time Zone and Time Offset heading, set a Time Zone option for the layer.
