Use web feature layers
Web feature layers (also known as feature services) are layers that are shared to support displaying, querying, and editing data on the web. As a service editor, ArcGIS Pro supports a wide range of geodatabase datasets and capabilities from supported databases. The following sections include common tasks for working with feature layers from the web in ArcGIS Pro.
For more information on the sharing process, see Share a web feature layer.
Web feature layer information model
In ArcGIS Pro, web feature layers support the following geodatabase functionality:
  • Simple geometry—points, lines, and polygons
  • Relationship classes
  • Attachments
  • Domains
  • Subtypes
  • Multipatches
  • Multipoints
For web feature layers on ArcGIS Enterprise that reference data from a registered data store, the following datasets are supported in addition to the datasets listed above:
  • Utility networks
  • Parcel fabrics
  • Topology
  • Annotations
  • Dimensions
  • 3D object feature layers
Datasets such as feature datasets and transportation networks are not currently supported.
Web feature layers that reference database data support simple points, lines, and polygon features.
View web feature layers in the Contents pane
You can add a web feature layer to a map or scene from your active portal connection, from an ArcGIS Server user connection, by opening a web map, or by specifying a URL when adding data from a path. Web feature layers can contain sublayers. You can add the entire layer or browse into the layer to add individual sublayers. When you add a web feature layer to a map, the layer is also added to the Contents pane as a group layer containing all of the sublayers. You can rearrange these sublayers in the group layer or move them out of the group layer to stand on their own. The group layer is used for organizational purposes and does not affect layer functionality. If you add individual sublayers to a map, they are represented individually in the Contents pane.
Learn more about how to add a web feature layer
Work with feature layers from the web
Once a web feature layer is added to ArcGIS Pro, it behaves in the same way as any other feature layer from a geodatabase. To get information about the layer, access the Layer Properties dialog box. Right-click the layer in the Contents pane and click Properties or double-click the layer name. On the Layer Properties dialog box, you can set definition queries and find information about extent, data source (URL), coordinate system, and other layer properties.
When using hosted web feature layers, the owner of the layer in the portal can add and delete fields and indexes for the layer. These are the only data definition language (DDL) operations currently supported for web feature layers in ArcGIS Pro. Additionally, if the layer has been shared with a shared update group, members of this group will also be able to add and delete fields and indexes for the layer.
The labeling, visibility range, and symbology for the layer are set automatically based on the settings from the portal or ArcGIS Server site where it resides. You can override these settings using the Appearance and Labeling tabs or the Layer Properties dialog box.
Learn more about how to set layer properties
To help ensure good performance with data from the web, ArcGIS Pro maintains a local cache for display, query, and edit operations.
Caution:
It is recommended that you publish layers without definition queries if you intend to edit the layers in ArcGIS Pro. This is because service-based definition queries and filters on views are not available to ArcGIS Pro. When using these layers, features that do not meet the definition query might display in ArcGIS Pro even though they are not visible in other applications. These features might disappear during the session but appear the next time ArcGIS Pro is opened.
Learn more about how caching works
Display limit notification
Certain web feature layers may have too many features for ArcGIS Pro to display all at once. When this limit is reached, a warning notification appears in the upper corner of the application indicating Feature limit exceeded! Not all features are displayed. This indicates that one or more layers did not draw completely. To see all features, you must zoom in to a smaller area so that fewer features are displayed.
Spatial references
ArcGIS Pro allows you to specify a spatial reference of a map. When a map is set to use a spatial reference that is different than the spatial reference of the data, ArcGIS Pro will request that the feature service project on the fly to the spatial reference of the map.
For web feature layers that reference a database, both the spatial reference of the underlying data and of the map used to publish will be recorded in the web feature layer's metadata. When these web feature layers are added to a map, ArcGIS Pro will use the source spatial reference. This can provide a performance benefit when querying and editing, as there is no on-the-fly projection of the spatial reference.
For hosted web feature layers, data is always copied into the back end data store using the spatial reference used by the map used to share the data. If the data being shared has a different spatial reference than that of the map, ArcGIS Pro will transform the data to that of the spatial reference of the map.
You can decide to use a different spatial reference by changing the map's spatial reference. For more information on how to change a map's spatial reference, see Specify a coordinate system.
Caution:
Using an older version of ArcGIS Enterprise or ArcGIS Server and a newer version of ArcGIS Pro may cause some projections to be unsupported. This is due to newer projections being added to ArcGIS Pro that had not been added to previous versions of ArcGIS Enterprise. In this scenario, feature layers may not draw and using a spatial reference supported by the server will be needed.
Edit web feature layers
Typically, editing web feature layers is the same as editing other vector data. The types of edits you can make to a web feature layer are controlled by the feature service properties. There are different editing patterns that are dependent on the data being published, the editor permissions, and which capabilities are enabled on the service. One such capability that affects editing patterns is the version management capability. When publishers enable this capability when they publish branch versioned data, it changes how editors can edit the web layer in ArcGIS Pro.
For more information on editing web feature layers, see Edit web feature layers.
Administrators and owners of the layer can edit feature layers in ArcGIS Pro even when editing is not enabled on the layer. This is true for feature layers that reference a registered data source (ArcGIS Server feature layers) and hosted feature layers.
Layer owners and administrators can also edit hosted feature layers in ArcGIS Enterprise and ArcGIS Online portals even if editing is not enabled on the layer. If the web feature layer has been shared with a shared update group, members of the group also have elevated privileges that allow them to edit the layer even if editing is not enabled on the layer.
Use ArcPy to work with data
You can use ArcPy to access web feature layers. You can open individual layers and tables by providing the URL to the feature service sublayer referenced by the layer.
Learn more about how to access web feature layers through ArcPy
Work with date fields
For a layer to be considered time enabled for use in ArcGIS Pro (for example, the time slider is available), time properties for your temporal layer must be time enabled on the feature service layer during or after publishing.
Coordinated universal time (UTC) is nearly equivalent with the current time at Earth's prime meridian (zero degrees longitude), located near Greenwich, England, and is a more precise successor of Greenwich Mean Time (GMT).
When you publish hosted feature layers, you can specify whether the date fields contain local time zone information. This enables the publishing process to transform the local time data into UTC for storage in the database. If you do not specify a time zone during publishing, date values are not converted and the data is assumed to be in UTC. When working with date and time fields in feature services, dates are generally assumed to be in UTC. When publishing feature layers that reference data in an enterprise geodatabase, if any date fields are stored in local time, you can specify a time zone for the date fields. This information is used by the feature service to convert and return date information in UTC.
You can configure feature services to have either preferred time zones or unknown time zones. For more information, see Service parameters.
When a service has a preferred time zone defined, all date values in the data will be presented in the preferred time zone. This means that for display, query, or editing, you will work in the preferred time zone only. When a service has an unknown time zone, there is no translation on the server reading the data from the data source. Therefore, ArcGIS Pro will not perform any translation for display, query, or editing.
When working with web feature layers that have neither a preferred time zone nor unknown time, there are no conversions applied to date fields for query or display purposes in ArcGIS Pro. Date values returned by queries in ArcGIS Pro are displayed in the UTC time returned from the web feature layer. This contrasts with other applications such as web browsers that use ArcGIS API for JavaScript. These web applications usually convert date values into the local time used on the device used to view the data. With feature layers published by reference date queries, calculations or edits may return unexpected values if the time zone of the data is not taken into account.
