Service parameters
The following service level parameters can be configured when sharing a web layer using ArcGIS Pro. Because these parameters are stored at the service level, when sharing multiple web layers, such as a map image layer with an associated web feature layer, these parameters are only set once and shared by both web layers. For more information about the relationship between a web layer and a service, see Understanding services, layers, and maps.
Service parameters available
Depending on your active portal and which layer types you selected, different parameters are available.
The workflows for setting service parameters for each type of web layer are different and are not discussed in detail here. Each web layer type has its own configuration topic you can refer to for more information:
Parameter
Maximum records returned by server
Clients, such as the ArcGIS Web APIs, can perform query operations to return specific information, or records, from a web layer. This property specifies how many records can be returned by the server to a client for any given query operation. Specifying a large number of records to be returned by the server can slow the performance of client applications consuming your web layer, such as web browsers, and your GIS server.
The default value is 2,000.
This parameter is available when sharing the following:
  • Map Image layer
  • Feature layer that copies all data to ArcGIS Enterprise
Max number of coded domains
An integer representing the maximum number of domain codes that can be returned from all fields, subtypes, layers, and tables in a map image layer.
In a large multiuser map service, the number of domain codes returned by the service may exceed the default value. If this occurs, the service continues to run normally, but the map service drops all domains to maintain server performance. Additionally, an error documenting the event is recorded in the server logs. If you require the map service to return a greater number of domain codes than the default value, specify the value. Note that the performance of the service may be affected when it must return more than 25,000 domain codes.
The default value is 25,000.
  • Map Image layer
Max image height
An integer representing the maximum height (in pixels) of images the map service will export.
The default value is 4,096.
  • Map Image layer
Max image width
An integer representing the maximum width (in pixels) of images the map service will export.
  • Map Image layer
Max sample size
An integer representing the maximum number of records that will be sampled when computing a class breaks renderer.
The default value is 100,000.
  • Map Image layer
Enable schema locking
This property determines whether the map service acquires schema locks for map layers that come from referenced datasets.
By default, this property is enabled on enterprise database data, shapefiles, and coverages. Locks are not placed on file geodatabases.
  • Map Image layer
Disable identify relates
This property determines whether the map service returns information about features from related tables and feature classes when you perform an identify operation.
By default, this property is not checked so the identify operation returns related information.
  • Map Image layer
Time zone of the data
If one of the layers you are sharing contains date fields that contain dates stored in a local time zone, such as eastern standard time, specify the time zone in which the dates are recorded. This allows the service to correctly convert date and time values when you interact with the service. If you do not specify a time zone, the dates will be assumed to be stored in UTC.
You must specify the time zone if your data has editor tracking enabled and uses database time.
The default value is None (Assumed UTC).
This setting applies in the following scenarios:
  • You are sharing data with date fields to ArcGIS Enterprise 11.5 and earlier.
  • You are sharing to ArcGIS Online or ArcGIS Enterprise 12.0 and later, and a time zone is not defined in the layer properties.
If you are sharing a map image layer to ArcGIS Enterprise 10.9 or later, choose Unknown if your map contains layers with date fields that do not have a known time zone or if multiple time zones are represented in the data. Unknown time zones do not apply to editor tracking date fields. Editor tracking date fields are in UTC even when the service's time is set to unknown.
  • Map Image layer
  • Feature layer to ArcGIS Online
  • Feature layer that copies all data to ArcGIS Enterprise 10.5.1 and later
  • Table (Hosted) to ArcGIS Online or ArcGIS Enterprise 10.7 and later
Preferred time zone for display
ArcGIS Pro will display date fields in the preferred time zone when you interact with the web layer. Date fields will be displayed in UTC if no preferred time zone is specified.
This parameter is available when sharing the following if a time zone other than None (Assumed UTC) or Unknown is selected:
  • Map Image layer
  • Feature layer that copies all data to ArcGIS Enterprise 11.1 and later
Adjust For Daylight Saving
If you specify a time zone other than UTC and you want the time zone or preferred time zone to account for daylight saving time, check this property.
The default value is not checked.
  • Map Image layer
