Text and Graphics settings
System administrators can manage many ArcGIS Pro user application settings.
The settings described below should be added under the TextAndGraphics element in the Pro.settingsConfig file.
Learn more about text and graphic default symbol options
DefaultFontName
In the user interface, on the Text and Graphics tab on the Options dialog box, click Default Font > Font name to access the corresponding setting.
Possible values are any valid font family name.
Set the default font through the application and access the value from the registry key HKEY_CURRENT_USER\SOFTWARE\ESRI\ArcGISPro\Symbology\Settings\DefaultFontName.
An example of this setting is shown below.
<DefaultFontName isLocked="true">Arial Narrow</DefaultFontName>
DefaultFontStyle
In the user interface, on the Text and Graphics tab on the Options dialog box, click Default Font > Font style to access the corresponding setting.
Possible values are any valid font style name.
Set the default font style through the application and access the value from the registry key HKEY_CURRENT_USER\SOFTWARE\ESRI\ArcGISPro\Symbology\Settings\DefaultFontStyle.
<DefaultFontStyle isLocked="true">Italic</DefaultFontStyle>
DefaultFontVariationSettings
In the user interface, on the Text and Graphics tab on the Options dialog box, click Default Font > Modify variable font axis values to access the corresponding setting.
This option is only available when a variable font is specified for the default font name. It is locked when the DefaultFontStyle setting is true.
Possible values are any valid axes tag. Examples include the following:
  • wght (weight)
  • wdth (width)
  • slnt (slant)
  • ital (italic)
  • opsz (optical size)
Set the default font variation settings through the application and access the XML from the registry key HKEY_CURRENT_USER\SOFTWARE\ESRI\ArcGISPro\Symbology\Settings\DefaultFontVariationXml. Paste this XML inside the DefaultFontVariationSettings node of the Pro.settingsConfig file.
<DefaultFontVariationSettings>
  <ArrayOfCIMFontVariation xsi:type='typens:ArrayOfCIMFontVariation'
    xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'
    xmlns:xs='http://www.w3.org/2001/XMLSchema' xmlns:typens='http://www.esri.com/schemas/ArcGIS/3.1.0'>
    <CIMFontVariation xsi:type='typens:CIMFontVariation'><TagName>wght</TagName><Value>300</Value>
    </CIMFontVariation>
    <CIMFontVariation xsi:type='typens:CIMFontVariation'><TagName>wdth</TagName><Value>87</Value>
    </CIMFontVariation>
  </ArrayOfCIMFontVariation>
</DefaultFontVariationSettings>
