Data guidelines and best practices
The following provides high-level guidance on how product data can be used within and shared outside ArcGIS Business Analyst.
See the Esri Master Agreement, Products and Services (E204) for full definitions, terms, and conditions.
Permitted uses
Keep the following in mind:
Use ArcGIS Business Analyst product data within the ArcGIS Business Analyst product you have licensed.
Use or enrich your own data with ArcGIS Business Analyst product data for analysis purposes as permitted, based on your Business Analyst license.
Create visual representations (reports, maps, and infographics) of ArcGIS Business Analyst product data for others to visualize using ArcGIS Experience Builder, ArcGIS Dashboards, and ArcGIS StoryMaps.
Create visual representations (reports, maps, and infographics) of ArcGIS Business Analyst product data to share in hard-copy or static electronic formats (for example, PDF, GIF, JPEG, dynamic HTML) with reports or documents with third parties.
Export and share ArcGIS Business Analyst online data from analytical workflows within your organization as permitted in the software with users who have the same Business Analyst software and data license.
Export ArcGIS Business Analyst local data for use in all ArcGIS products by the licensed user only, or share with others within your organization that have the same Business Analyst software and data license.
Caution:
You must ensure that proper attribution to Esri or Esri licensors is included when using ArcGIS Business Analyst product data in data representations.
Restrictions
The following restrictions apply:
You may not use ArcGIS Business Analyst product data to compile, store, scrape, download, or enhance a compilation of information that is resold, redistributed, cross-compiled, or provided to a third party for revenue-generating purposes.
You may not use ArcGIS Business Analyst product data for direct marketing purposes.
You may not use ArcGIS Business Analyst product data without an active Business Analyst license.
You may not export Business Analyst online data to share, publish, or consume outside of an ArcGIS environment or with users who do not have the same Business Analyst software and data license.
You may not export Business Analyst local data to share, publish, or consume outside of an ArcGIS environment or with users who do not have the same Business Analyst software and data license.
Data storage best practices
Cloud storage services, such as Microsoft OneDrive and Google Drive, are not recommended for storage of local datasets used in ArcGIS Pro.
Contact an Esri representative
If you have further questions or are interested in using ArcGIS Business Analyst product data outside of the permitted uses listed above, use the Contact Sales form and an Esri representative will contact you.
