Work with operators in map algebra
Available with Spatial Analyst license.
Available with Image Analyst license.
In map algebra, operators apply a mathematical operation on input rasters and numbers.
Operators are generally placed between two inputs (operands) to perform a mathematical operation (for example, outVar = 3 + 7). In map algebra, operands can be rasters or numbers. To use an operator with a raster, the raster must be a Raster object.
The table below provides a quick reference indicating how current map algebra operators have been implemented in relation to Python operators.
Operation |
Python operator |
Map algebra operator |
Geoprocessing tool |
Arithmetic |
Addition |
Plus |
Division |
Divide |
Integer Division |
N/A |
Modulo |
Mod |
Multiplication |
Times |
Power |
Power |
Subtraction |
Minus |
Unary Minus |
Negate |
Unary Plus |
N/A |
Boolean |
Boolean And |
N/A |
Boolean And |
Boolean Complement |
N/A |
Boolean Not |
Boolean Exclusive Or |
N/A |
Boolean XOr |
Boolean Or |
N/A |
Boolean Or |
Relational |
Equal To |
Equal To |
Greater Than |
Greater Than |
Greater Than And Equal To |
Greater Than Equal |
Less Than |
Less Than |
Less Than And Equal To |
Less Than Equal |
Not Equal To |
Not Equal |
Bitwise |
Bitwise And |
N/A |
Bitwise And |
Bitwise Complement |
N/A |
Bitwise Not |
Bitwise Exclusive Or |
N/A |
Bitwise XOr |
Bitwise Left Shift |
Bitwise Or |
N/A |
Bitwise Or |
Bitwise Right Shift |
Operator rules
The following are operator rules:
When only numbers are used with operators, the result will be a number.
# outVar will be assigned 10 outVar = 3 + 7When using operators with rasters, the raster must be a
Rasterobject.outRas = Raster("inraster1") + Raster("inraster2")When a raster operand is used, the result is a
Rasterobject.# In the following statement, 4 is added to each cell value in inraster1 outRas = Raster("inraster1") + 4 outRas2 = Raster("inraster") + math.piIn the above statement,
piis used from the Pythonmathmodule. Themathmodule also includes the base of the natural logarithm,math.e, which can also be used in a map algebra statement.Some operators can precede a
Rasterobject or a number.outRas = -Raster("inraster")The Boolean (
~,&,^,|) operators will perform a Boolean operation when one or more inputs (operand) is a raster. If both inputs (operands) are numbers, these operators will perform Bitwise operations.
Tip:
Spaces are not necessary between operators but are recommended for readability.
Tools and operators can be nested to create complex statements.
Multidimensional raster operator rules
The following are multidimensional raster operator rules:
When an operator is used with a multidimensional raster and a number, the result is a multidimensional
Rasterobject with the same variables and dimensionality as the input.# In the following statement, 100 is added to each cell in # each slice of in_multidem_raster out_multidem_raster = in_multidem_raster + 100When an operator is used with a multidimensional raster and a non-multidimensional raster, the result will be a multidimensional
Rasterobject with the same variables and dimensionality as the input.If the input
Rasterobjects do not overlap, no result is returned.# In the following statement, the cell values from in_raster are added to # the cell values in each slice of in_multidem_raster. out_multidem_raster = in_multidem_raster + in_rasterWhen an operator is used with two multidimensional rasters, the result will be a multidimensional
Rasterobject containing only variables and dimensionality that are common between the inputs. For example, if one multidimensional raster contains daily temperature data for 1995–2015, and another multidimensional raster contains daily temperature data for 2001–2005, the result of an operator used with both multidimensional rasters will include only daily temperature data for 2001–2005.If the input multidimensional
Rasterobjects do not have common variables and dimensionality, no result is returned.# In the following statement, the cell values in each slice from in_multidem_raster1 # are added to the cell values in each slice from in_multidem_raster2, only where variables and # dimensionality overlap. out_multidem_raster = in_multidem_raster1 + in_multidem_raster2
Operator precedence
The precedence value determines the order in which operators are run. The operator with the higher precedence will be processed first. If two operators have the same precedence value, they will be processed in a left-to-right order in an expression.
You can use parentheses to override the precedence priority, with the operation in the deepest parentheses being processed first no matter what operator is specified.
The following table lists all the map algebra operators in order from lowest precedence to highest precedence. Each of the operators that are listed in the same row have the same precedence.
Reference |
Less Than, Less Than Equal, Greater Than, Greater Than Equal, Equal To, Not Equal |
