Spatially enable an SQLite database
To spatially enable an existing SQLite database, do one of the following:
Install SpatiaLite. See the SpatiaLite documentation for information on adding SpatiaLite to an SQLite database.
Use SQL to load the ST_Geometry library and create the ST_Geometry type in an existing SQLite database.
Use SQL to load the ST_Geometry library and create an OGC GeoPackage.
Add ST_Geometry tables to SQLite
To add ST_Geometry system tables to an existing SQLite database requires the following:
The database file must have the extension
.sqlite; therefore, if the database you want to use has a different extension, rename it. For example, if the database is namedprojdata.d1, rename it toprojdata.sqlitebefore adding the ST_Geometry type to it.The database cannot already contain another spatial type.
The Esri ST_Geometry library must be accessible from the SQL editor from which you load it. You can obtain the library from My Esri. Download the ST_Geometry package from Database Support files and extract the package's contents.
If you store the SQLite database on a Linux machine, the
libstdcc++.so.6.0.29library or a later release must be present. If it is not, place thelibstdcc++.so.6library from the extracted package in the same local Linux directory as thelibstgeometry_sqlitelibrary.
If necessary, rename the database file to have the extension
.sqlite.Connect to the database using an SQL editor, such as
sqlite3.exe.Load the ST_Geometry library.
This example loads the ST_Geometry library to an SQLite database on a Microsoft Windows computer:
SELECT load_extension('stgeometry_sqlite.dll','SDE_SQL_funcs_init');This example loads the ST_Geometry library to an SQLite database on a Linux computer:
SELECT load_extension('libstgeometry_sqlite','SDE_SQL_funcs_init');Call the
CreateOGCTablesfunction to add ST_Geometry tables to the database.SELECT CreateOGCTables();
Create a GeoPackage
To convert an existing SQLite database to a GeoPackage requires the following:
.gpkg; therefore, if the database you want to use has a different extension, rename it. For example, if the database is namedstudy.db, rename it tostudy.gpkgbefore you convert it to a GeoPackage.The database cannot already contain another spatial type.
.gpkg.Connect to the database using an SQL editor, such as
This example loads the ST_Geometry library to an SQLite database on a Windows computer:
CreateGpkgTablesfunction to add GeoPackage tables to the database.SELECT CreateGpkgTables();
