File geodatabases SQL reference
You can use SQL queries to access and analyze data in a file geodatabase.
The following sections provide descriptions and examples of SQL expressions, functions, operators, keywords, and clauses that can be used to query tables, feature classes, and views in file geodatabases.
Alias
You can use the AS keyword to specify an alias for a field name, table name, or the values returned by the SQL query. This provides a more understandable output.
In the following example of using the AS keyword, the results of subtracting the values in the POP1990 column from the values in the POP1997 column are returned under the alias PopChange.
SELECT COUNTY_NAME, POP1997 - POP1990 AS PopChange
FROM counties
ORDER BY COUNTY_NAME
CASE expressions
A CASE expression evaluates a list of specified conditional expressions and returns results based on those expressions.
The following statement includes a set of conditions in a CASE expression that returns the words low, average, or high depending on salary values.
SELECT name,salary,
CASE
WHEN salary <= 2000 THEN 'low'
WHEN salary > 2000 AND salary <= 3000 THEN 'average'
WHEN salary > 3000 THEN 'high'
END AS salary_level
FROM employees
Functions
The following is a list of functions supported by file geodatabases.
Date functions
Date functions return date and time values.
Returns the current date provided by the operating system of the machine where you run the SQL query. |
Returns the portion of the date-time expression (denoted by The |
Returns the current time provided by the operating system of the machine where you run the SQL query. |
Returns the current time and date provided by the operating system of the machine where you run the SQL query. |
Numeric functions
Numeric functions perform operations on numeric values. All numeric functions return a numeric value.
Arguments denoted as numeric_exp, float_exp, or integer_exp can be the name of a column, the result of another scalar function, or a numeric-literal, for which the underlying data type could be represented as a numeric type.
Returns the absolute value of the number denoted by the |
Returns the arccosine value of the number denoted by the |
Returns the arcsine value of the number denoted by the |
Returns the arctangent value of the number denoted by the |
Returns the smallest integer greater than or equal to the value denoted by the |
Returns the cosine value of the angle (in radians) denoted by the |
Returns the largest integer less than or equal to the number denoted by the |
Returns the natural logarithm of the value denoted by the |
Returns the base 10 logarithm of the value denoted by the |
Divides the |
Returns the value of |
Returns the If the value denoted by |
Returns an indicator of the sign (negative, positive, or zero) of the value denoted by the If the |
Returns the sine of the |
Returns the tangent of the |
Returns the |
String functions
String functions perform operations on string values (text characters).
Arguments denoted as string_exp can be the name of a column, a character-string-literal, or the result of another scalar function, where the underlying data type can be represented as a character type.
Arguments denoted as character_exp are variable-length character strings.
Arguments denoted as start or length can be a numeric-literal or the result of another scalar function, where the underlying data type can be represented as a numeric type.
These string functions are 1-based; that is, the first character in the string is character 1.
Returns the length, in characters, of the string expression. |
Returns a character string that is the result of concatenating the text in |
Returns a string equal to that in the |
Returns the position of the first character expression in the second character expression. The result is an exact numeric with an implementation-defined precision and a scale of zero. |
Returns a character string that is derived from the text represented by the |
Returns the text specified for the |
Aggregate functions
Use an aggregate function to perform a calculation on a specified set of values, to return a single value that is a result of that calculation.
Calculates the average of all values in the set. Null values are ignored. |
Returns the maximum value in the set. Null values are ignored. |
Returns the minimum value in the set. Null values are ignored. |
Returns the sample standard deviation of the expression. |
Returns the population standard deviation of the expression. |
Adds the values in the set and returns the resultant sum. Null values are ignored. |
Returns the sample variance of the expression. |
Returns the population variance of the expression. |
COALESCE
The COALESCE function returns the first non-null field value among its arguments.
SELECT Name, COALESCE(Business_Phone, Cell_Phone, Home_Phone)
Contact_Phone
FROM Contact_Info
The following is a sample of records from the Contact_Phone table in the geodatabase:
Name |
Business_Phone |
Cell_Phone |
Home_Phone |
Jeff |
531-2531 |
622-7813 |
565-9901 |
Laura |
772-5588 |
312-4088 |
Peter |
594-7477 |
Including the COALESCE function in the expression results in the following output:
Name |
Contact_Phone |
Jeff |
531-2531 |
Laura |
772-5588 |
Peter |
594-7477 |
NULLIF
The NULLIF function returns NULL if the two parameters provided are equal; otherwise, the value of the first parameter is returned.
SELECT Location, NULLIF(Sales, Forecast) AS Results
FROM StoreSales
The following is an example of values in the location, sales, and forecast fields of the StoreSales table:
Location |
Sales |
Forecast |
Redlands |
39000 |
55000 |
Palm Springs |
60000 |
61000 |
Riverside |
40000 |
40000 |
Running the expression with a NULLIF function on the StoreSales table returns the following results:
Location |
Results |
Redlands |
39000 |
Palm Springs |
60000 |
Riverside |
NULL |
Clauses
Clauses work as filters that restrict, order, or modify the results of a query expression.
GROUP BY
The GROUP BY clause is used to collect data across multiple records and group the results by one or more columns.
The following statement summarizes (adds) all values in the POP1990 field in the counties table, and groups the values by state. Values are also returned in ascending alphabetical order by state name.
SELECT state_name, SUM(POP1990) AS TotalPopulation
FROM counties
GROUP BY STATE_NAME
ORDER BY STATE_NAME
GROUP BY clauses can include aggregation functions such as MIN, MAX, and SUM.
HAVING
Use the HAVING clause with aggregate functions in place of a WHERE clause.
In the following example, the MAX aggregate function is used to return the highest salary stored in the employees table. The HAVING clause restricts that value to the maximum value below 50000.
SELECT department, MAX(salary) AS Highest_salary
FROM employees
GROUP BY department HAVING MAX(salary) < 50000
JOIN clauses
JOIN clauses return the combined records from two or more tables.
CROSS JOIN
The following example returns every row in table1 matched with every row in table2 and every row in table2 matched with every row in table1. If table1 contains 100 rows and table2 contains 1,000 rows, 100,000 rows will be returned. This type of join should be used carefully, as the number of returned rows will get large fast.
SELECT Table1.name, Table1.Address, Table2.name, Table2.Salary
FROM Table1
CROSS JOIN Table2
INNER JOIN
The following statement returns the rows from both tables when the key values (Table1.C1, Table2.C3) match. No other rows will be returned from either table.
SELECT Table1.C1, Table1.C2, Table2.C3, Table2.C4
FROM Table1
INNER JOIN Table2 ON Table1.C1 = Table2.C3
LEFT OUTER JOIN
The following statement returns all of the rows from the left table (Table1) and only the rows from the right table (Table2) when the key values match (Table1.C1, Table2.C3).
FROM Table1
LEFT OUTER JOIN Table2 ON Table1.C1 = Table2.C3
RIGHT OUTER JOIN
This statement returns all of the rows from the right table (Table2) and only the rows from the left table (Table1) when the key values match (Table1.C1, Table2.C3).
SELECT * FROM Table1
RIGHT OUTER JOIN Table2 ON Table1.C1 = Table2.C3
ORDER BY
The ORDER BY clause specifies sort order. The order can be ascending (ASC) or descending (DESC). By default, values are sorted in ascending order.
You can also specify a collation when you use the ORDER BY clause. Collation type arguments include the following:
BINARY(BIN)—Binary collation is both case and accent sensitive. When you use this collation argument, lowercase letters sort ahead of their uppercase versions when sorting in ascending order, and accents are sorted ahead of letters when sorting in ascending order. You can specify eitherBINARYorBINin the query.CASESENSITIVE(CASE)—A case-sensitive collation distinguishes between uppercase and lowercase letters. When you use this collation argument, lowercase letters sort ahead of their uppercase versions. You can specify eitherCASESENSITIVEorCASEin the query.NOCASESENSITIVE(NOCASE)—TheNOCASEargument does not distinguish between uppercase and lowercase letters, which means that case is ignored for the sort order. You can specify eitherNOCASESENSITIVEorNOCASEin the query.
You cannot use an ORDER BY clause when defining a view.
The following are examples of using the ORDER BY clause:
Values will be returned in ascending alphabetical order by state name.
SELECT STATE_NAME, POP1990
FROM counties
ORDER BY STATE_NAME
Values will be returned in descending alphabetical order by state name, with uppercase names returned first.
FROM counties
ORDER BY STATE_NAME
COLLATE CASE DESC
Operators
The following operators are supported by file geodatabases.
Arithmetic operators
Use an arithmetic operator to add, subtract, multiply, and divide numeric values.
Arithmetic operator for multiplication |
Arithmetic operator for division |
Arithmetic operator for addition |
Arithmetic operator for subtraction |
SIMILAR TO
SIMILAR TO is a comparison operator that evaluates string values and returns true or false.
The following example query evaluates the values in the state_name field and returns true if the word North appears at the start of any values in that field or returns false if no value in the state_name field starts with the word North.
SELECT state_name
FROM counties
WHERE state_name SIMILAR TO 'North%'
Values that begin with the word north (with a lowercase n) will return false for the example above because the string comparison is case sensitive.
