Connections to read-only Oracle databases
If you use Oracle Data Guard, you can connect to one of the standby databases for read-only access. This allows you to move some of the load off your primary database for such operations as accessing data through a map service or including a query-only, sync-enabled feature service for reference purposes in a map you take offline.
Connect to the standby database as you normally would connect to any Oracle database from ArcGIS.
Be aware of the following when you connect to a read-only database:
  • If the map contains data from a read-only database, publishing an editable feature service will not fail, but you won't be able to edit the data through the resultant feature service.
  • You must reconnect if a failover occurs and access to the Oracle Data Guard database is interrupted while you are connected to the database from ArcGIS Pro.
  • Web services running on an ArcGIS Server site or ArcGIS Enterprise organization automatically resume the connection once the database is available.
