Compatibility between ArcGIS clients and geodatabases in SAP HANA
You can connect to a geodatabase in SAP HANA from the following ArcGIS clients:
ArcGIS Pro
ArcGIS Server
ArcGIS Enterprise on Microsoft Windows, Linux, and Kubernetes
Connections from retired ArcGIS versions are not supported.
The geodatabase version for an enterprise geodatabase is stored in a system table and is available to the geodatabase administrator from the Database Properties dialog box. The version indicates the client version you used to create or upgrade the geodatabase. This geodatabase version is primarily used by Esri Technical Support to troubleshoot issues; it does not entirely reflect the functionality available to you, because a lot of geodatabase functionality is implemented in the clients that access the geodatabase and not in the geodatabase itself.
You do not have to keep your geodatabase and ArcGIS clients at the same release, but it is recommended that you do so. Geodatabases and client software are designed to work together, and if you let one get too many releases away from the other, you risk encountering problems or unexpected behavior.
This is especially true when you use a combination of client versions at your site. A newer client can create newer dataset types in the geodatabase that older clients cannot access. For enterprise geodatabases, waiting too long between geodatabase upgrades may mean you have to upgrade the underlying database more than once before you can upgrade the geodatabase.
Connecting from newer clients to earlier release geodatabases allows you to use the geodatabase without having to upgrade it at the same time the clients are upgraded. It also allows you to have mixed-release client installations at your site. Keep the following in mind, though, when using mixed releases:
The version of the database management system you use must be compatible with the ArcGIS client version from which you connect. See ArcGIS system requirements for using SAP HANA for information about supported versions. Use the Other versions drop-down list to access information for earlier software releases and other operating systems.
Use supported versions of ArcGIS for your clients and geodatabase.
ArcGIS clients also include the API for that client. Therefore, the same mixed-release rules apply when accessing the geodatabase using the API.
To connect from newer ArcGIS clients to an earlier release enterprise geodatabase, apply the latest patch to the geodatabase for its release if one exists.
When you use clients that connect to an ArcGIS Server service, such as ArcGIS Field Maps or ArcGIS Survey123, ArcGIS Server is actually the client to the geodatabase. For these cases, ensure that your ArcGIS Server and geodatabase versions are compatible.
Older ArcGIS clients can open, query, edit, and save data in newer release geodatabases, but they cannot open datasets that participate in newer functionality. You will encounter error messages when you try to access a new type of dataset from an older ArcGIS client, including the following:
The version of the Geodatabase client is incompatible with the dataset and cannot open it.
Failed to add data, unsupported data type.
If you use geodatabase replication, the child replica geodatabase must be the same geodatabase release as or a later release than the parent replica geodatabase.
