ArcGIS requirements for using SAP HANA
ArcGIS Pro and ArcGIS Enterprise support connections to SAP HANA databases and enterprise geodatabases in SAP HANA.
Visit Esri Technical Support for information about the Esri Supported Environment Policy.
The information below applies to ArcGIS Enterprise 12.1 and ArcGIS Pro 3.7.
Supported database versions
SAP HANA 2.0 SPS 07 and later service pack releases are supported for use with ArcGIS.
Supported operating systems
SAP HANA is available either in the cloud or as a preconfigured system on Linux. Contact SAP for the available configurations.
Database requirements and limitations
The following limitations apply when using SAP HANA with ArcGIS:
  • If you use branch versioned data, you must use SAP HANA 2.0 SPS 08 rev 81 or a later service pack release.
  • If you use SAP HANA 2.0 SPS 08 rev 81 or a later service pack release, and the database contains a geodatabase, you must grant users the following in the database:
    • EXECUTE ON ACQUIRE_APPLICATION_LOCK
    • EXECUTE ON RELEASE_APPLICATION_LOCK
  • When you use a database connection file (.sde) to access SAP HANA data in ArcGIS Pro, you can only edit data that is registered with the geodatabase. To edit database data, publish an editable web feature layer that references the database data, and edit through the web feature layer.
Cloud support
See Requirements for using ArcGIS with databases in the cloud for information about support for database services and databases deployed in the cloud.
Software required to connect to SAP HANA
Your ArcGIS client machines that connect to SAP HANA—for example, the ones running ArcGIS Pro or ArcGIS Server—must have a supported SAP HANA client installed and configured.
SAP HANA clients are available to existing SAP users from the SAP Support Portal under Software Downloads.
Install a version of the SAP HANA client that is supported for the version of SAP HANA to which you connect.
It is recommended that ArcGIS clients use the newest SAP HANA client supported for the SAP HANA database version to which you connect.
