Edit STAC connection properties
The STAC Connection Properties dialog box is displayed when you right-click an existing STAC connection and click Properties. It contains the following parameters that were provided when the STAC connection was created:
  • Connection
  • STAC API Authentication
  • Custom Headers
  • Custom Parameters
  • Cloud Storage Connections
You cannot make changes to the Connection parameter. The STAC Connection Properties dialog box allows you to only edit the properties of an existing connection. You can edit STAC API Authentication to provide credentials for connections that require additional parameters such as OAuth authentication. You can also edit Custom Headers and Custom Parameters for the STAC connection, and add or remove Cloud Storage Connections.
