Explore STAC pane
The Explore STAC pane allows you to display and select the collections and items to add to ArcGIS Pro.
Dynamic and static catalogs
There are two types of catalogs: dynamic and static. ArcGIS Pro supports a wide range of these catalogs.
See The STAC Specification on the STAC website to learn more about dynamic and static catalogs.
Explore dynamic catalogs
The Explore STAC pane displays the dynamic catalogs on two tabs: the Parameters tab, which includes a set of search filters, and the Results tab, which displays the results based on the search parameters provided. You can select an item from the Results tab, view its footprints and properties, and add it to a map, scene, or mosaic dataset for further analysis and processing.
To open the Explore STAC pane, in the Catalog pane, right-click the STAC connection listed under STACs, and click Explore STAC. By default, the Explore STAC pane opens on the Parameters tab.
Parameters tab
On the Parameters tab, you can view, search, and select the STAC collections by applying various filters to display the datasets on the Results tab.
Parameters tab in the Explore STAC pane
You can filter the results of your STAC search using the following options:
  • Search Collections—Display all the available STAC collections and catalogs in the connection, and choose one or multiple collections and catalogs.
  • Description—Shows the description of the STAC connection.
  • Date and Time—Select the Start Date and End Date values to display the results in the selected STAC collections/catalogs created within the time frame. Additionally, you can select other layers that are open in the map to filter time-enabled layers that fall within the specific time period.
  • Extent—Filter the items in the current map view.
  • ID(s)—Filter the items by ID.
  • Attributes—Specify Field and Type values for an attribute. Alternatively, you can build a custom query based on multiple attributes using the Where clause in the definition query builder.
  • Items per page—Set the number of items to display per page.
Click the View Results button or the Results tab to view the results.
Results tab
On the Results tab, you can view and select the STAC items from the collections based on the provided search parameters, view their footprints and properties, and add them to a map, scene, or mosaic dataset. Additionally, you can directly add multiple STAC items as a mosaic layer to a map or scene, allowing you to add and work with a single layer and save the selection of STAC items to your local file system.
Results tab in the Explore STAC pane
The list is displayed in the form of cards that contain metadata about the items displayed. The cards are sorted based on the field that is displayed in bold at the top of the card.
Use the options on the toolbar displayed above the items list to do the following:
Select All check box
Select all items displayed in the list.
Add button Add items to the map, scene, or mosaic dataset
You can add one or more selected STAC items to a new or current map, a new global or local scene, or a mosaic dataset using the following drop-down options:
  • Add to Current Map—Add the selected STAC item to the current map.
  • Add to New Map—Add the selected STAC item to a new map.
  • Add to New Global Scene—Add the selected STAC item to a new global scene.
  • Add to New Local Scene—Add the selected STAC item to a new local scene.
  • Add to Mosaic Dataset—Add the selected STAC item to a mosaic dataset.
Alternatively, you can add all the items listed on the Results tab directly to a mosaic dataset using this option.
  • Add all items to Mosaic Dataset—Add all STAC items on the Results tab to a mosaic dataset.
    Before using this option, ensure that you set the required filters on the Parameters tab such as Extent, Date and Time, and Attributes to narrow down the datasets that you want to add to a mosaic dataset.
Add as Mosaic Layer to Current Map button Add items as Mosaic Layer to map or scene
Add multiple STAC items as a mosaic layer to the current map. Alternatively, you can add it to a new map, or a new scene using the drop-down options.
Save button
You can save one or more selected items listed on the Results tab using Save selected items option and save all the items using Save all items option.
Save Results
Before using the Save all items option, ensure that you set the required filters on the Parameters tab such as Extent, Date and Time, and Attributes as it might take time depending on the number of items in the Results.
Sort By button Sort by ID
Choose a different field for sorting.
Sort Order button Sort by Name
Sort the items in ascending or descending order.
Refresh button Refresh
Refresh the results based on the new map view extent or selection.
Configure Results button Compare Results
Edit the way the metadata is displayed on the cards. You can display four fields on each card. You can also show thumbnails of the datasets.
Use the buttons that appear on each card, or the check box and Add button, to work with a single item or a list of items. These buttons and their functions are described in the following table:
Button
Show Footprint button
Show Footprint
Show the footprints of the selected STAC items on the map. It allows you to draw the extent of the STAC item and see where it falls on the map.
Properties button Configure parameters
View the properties of the selected STAC items on the Results tab. It lists the metadata and asset information of the STAC item as the STAC Item Metadata and STAC Item Assets properties on the Raster Properties dialog box.
Add to Current Map button Add to the map, scene, or mosaic dataset
Add the selected STAC item to the current map, a new map, a new scene, or a mosaic dataset.
When adding multidimensional data into Pro using the STAC connection, the Add Multidimensional Data dialog box appears, allowing you to choose the variables you want to work with.
Explore static catalogs
Though the Explore STAC pane treats both the dynamic and static catalogs the same, there is a difference in the way the catalogs and items are listed for static catalogs.
The Explore STAC pane displays the static catalogs on two tabs: the Catalogs tab, which lists the catalogs, and the Items tab, which displays the items based on the catalog selected. You can select an item from the Items tab; view its footprints and properties; add it to a map, scene, or mosaic dataset; or add multiple items as a mosaic layer for further analysis and processing.
Catalogs tab
The Catalogs tab displays the static catalogs list with a description.
Catalogs tab in the Explore STAC pane
Click the catalog until it displays the items based on the directory structure. This opens the items on the Items tab.
Items tab
Once the catalog is chosen, the associated items appear on the Items tab.
Items tab in the Explore STAC pane
The items are displayed on Items tab similar to the Results tab of dynamic catalogs. The same options to show footprint, view properties, add item to a map, scene or mosaic dataset, add items as a mosaic layer, sort, refresh, and configure results are available.
Once the STAC item is added to the map, it is presented, managed, and processed consistently with other layers and content.
