Migrate a raster catalog to a mosaic dataset
Available with Standard or Advanced license.
ArcGIS Pro no longer supports raster catalogs. To use your data that was stored in a raster catalog, you need to convert it into mosaic datasets.
Create a mosaic dataset inside a geodatabase using the Create Mosaic Dataset tool.
Open the Add Rasters To Mosaic Dataset tool to populate the mosaic dataset.
For Raster Type, choose Table.
For Input Data, browse to and choose the raster catalog you are converting to the mosaic dataset.
Click Run to run the tool.
You now have a mosaic dataset for use in ArcGIS Pro.
