Mosaic Dataset Analyzer: Error 70127
Available with Standard or Advanced license.
Warning
The pixel type of the raster associated with the mosaic dataset item indicates that pixel values might be outside of the range allowed by the mosaic dataset.
There are one or more mosaic dataset items that have a larger bit depth than the mosaic dataset.
Solution
In the Stretch raster function, the General tab has an Output Pixel Type parameter. Make sure that the pixel type in the function matches the pixel type of the mosaic dataset. Using the Raster Functions Batch Editor to insert or edit the Stretch function can be helpful.
Alternatively, you can open the Mosaic Dataset Properties page and edit the pixel depth property to match the pixel depth of the mosaic dataset items.
