Mosaic Dataset Analyzer: Warning 71145
Available with Standard or Advanced license.
Warning
The top level function associated with the mosaic dataset item does not have histogram and statistics.
Statistics are required in order to perform color correction. The last function in the function chain does not have statistics calculated; therefore, color correction cannot be done.
Solution
Use the Build Pyramids and Statistics tool with the following parameters:
  • Build Pyramids unchecked
  • Calculate Statistics checked
  • Skip Existing unchecked
  • Include Source Datasets unchecked
