Mosaic Dataset Analyzer: Warning 71152
Available with Standard or Advanced license.
Warning
The mosaic dataset item references a nonthematic raster with pyramids built using the nearest neighbor resampling method.
One or more mosaic dataset items have continuous data that is using the nearest neighbor pyramid resampling. Continuous surfaces should use either the bilinear interpolation or cubic convolution resampling method.
Solution
Use the Build Pyramids and Statistics tool on the associated mosaic dataset items. When running the tool, be sure to turn off the calculation of statistics, and set the resampling method to either Bilinear or Cubic.
