Oriented imagery layer
An oriented imagery layer is a type of feature layer for visualizing oriented imagery in the context of a map or a 3D scene.
An oriented imagery feature service or an oriented imagery dataset is visualized on the map or scene as an oriented imagery layer. When added to the map, each point in the layer indicates the camera location where an image was acquired. The attributes of the points include the path to the stored image and the key metadata required to visualize the image in the oriented imagery viewer.
There may be an optional oriented imagery footprint layer showing the areas on the map where the oriented imagery layer has coverage. When an oriented imagery dataset with a Footprint Item property is added to the map, the oriented imagery layer and oriented imagery footprint layer are added to the Contents pane as two separate layers when the footprint feature class and the oriented imagery dataset are in the same geodatabase.
Alternatively, if the data source is a feature service in ArcGIS Online or ArcGIS Enterprise, both the footprint feature layer and oriented imagery layer are sublayers of the same feature service. When this feature service is added to the map, the oriented imagery feature layer and oriented imagery footprints feature layer are added to the Contents pane as a group layer.
Layer attribute table and properties
The layer inherits the attributes and properties of the source oriented imagery dataset, or oriented imagery feature service, that is added to the map.
The oriented imagery layer primary properties like Maximum Distance, Coverage Percentage, and oriented imagery layer orientation properties like Camera Heading, Camera Pitch, Camera Roll, Camera Height, Horizontal Field Of View, Vertical Field Of View, Near Distance, Far Distance, and Image Rotation can be edited on the layer instance. Editing the oriented imagery layer properties will not impact the source data properties.
For an oriented imagery layer, if a property field is not defined in the attribute table, the property field definitions in the oriented imagery dataset property are used. However, if a property field is explicitly defined in the attribute table, it takes precedence over the definition in the oriented imagery dataset properties. For example, if a value for Camera Pitch is defined both in the attribute table and oriented imagery dataset property, the definition in the attribute table is used.
Oriented imagery layer ribbon
When an oriented imagery layer is explicitly selected in the Contents pane, the Oriented Imagery Layer ribbon is displayed. Selecting the group layer (in the case of a feature service) or oriented imagery footprint layer does not display the Oriented Imagery Layer ribbon.
Explore Images tool
The Explore Images tool allows you to view oriented imagery associated with any location in a map or scene. The tool provides multiple ways to search, filter, and view imagery. For more on this tool capability, refer Explore Images.
If an accompanying footprint layer is available, use it as a reference to identify the visible extent of the images on the map. You can use the Navigation and Image Gallery tools in the oriented imagery viewer to explore other images of the selected map location.
Show the Current Footprint, Footprints, and Camera Locations tools
There are three graphics layers, Current Footprint, Footprints, and Camera Locations, that can be viewed to understand how the images in the oriented imagery relate to the map. To view any of the graphical layers, select the relevant button on the Oriented Imagery Layer ribbon. These are toggle buttons. To hide a graphical layer, click the selected button again.
When selected, the tools do the following:
  • Current Footprint displays the current footprint of the image as a red polygon on the map. In a scene, the current footprint is displayed as a 3D frustum. If you zoom or pan in the oriented imagery viewer, the footprint dynamically updates to highlight the areas on the map that are visible in the image.
  • Footprints displays the coverage footprints in blue for all the images that contain the selected point (marked by a red cross red cross) on the map or scene.
  • Camera Locations displays those camera locations from which the selected point is visible. The camera locations are marked in blue.
The Current Footprint, Footprints, and Camera Locations graphics layers cannot be accessed from the Contents pane, and their symbology cannot be modified.
Additional tools
The following tools can help you better understand oriented imagery:
  • Use the Map-Image Location tool to perform the image-to-ground and ground-to-image transformations. It identifies the same location in map space and in image space (oriented imagery viewer). When you select the tool and click the image, the corresponding location on the map is marked with a red diamond. Alternatively, if you click the map, the corresponding location in the image is marked with a red diamond.
  • Use the Reset button to remove any oriented imagery graphics layers from the map, refresh the oriented imagery viewer, and reflect changes such as renaming, and symbology updates made on the feature layer.
