Oriented imagery table
An oriented imagery table defines metadata for a collection of images. It is used as an input to the Add Images To Oriented Imagery Dataset geoprocessing tool.
The oriented imagery table can be used for adding images in the following instances:
  • The image metadata is stored separately from the image files.
  • The image metadata needs preprocessing before oriented imagery dataset inclusion.
  • You want to use the image orientations defined by the Matrix, or Omega, Phi, and Kappa fields.
If any of the optional fields in the oriented imagery table has the same value for all images and the field is an oriented imagery dataset property, a value for the field can be defined in the oriented imagery dataset property and removed from the oriented imagery table. For example, if all images use the same elevation source, the field can be defined as an oriented imagery dataset property, assigned the common value, and removed from the oriented imagery table. All the images will use the same value for the elevation source.
Oriented imagery table fields
The fields supported in the oriented imagery table are listed below. When a field is defined in the oriented imagery table, it takes precedence over the definition in the oriented imagery dataset properties. Additional fields in the oriented imagery table can be included in the output oriented imagery dataset if the Include all fields from input table parameter is checked in the Add Images To Oriented Imagery Dataset tool.
Fields supported in the oriented imagery table
Field name
Field type
Data type
X
Required
Numeric
The x-coordinate of the camera location in the ground coordinate system. The units are the same as the coordinate system units defined in the SRS field.
Y
Required
Numeric
The y-coordinate of the camera location in the ground coordinate system. The units are the same as the coordinate system units defined in the SRS field.
Z
Optional
Numeric
The z-coordinate of the camera location in the ground coordinate system. The z-coordinate units must be consistent with the x- and y-coordinate units and can be defined by the vertical coordinate system.
The z-coordinate is typically expressed as orthometric heights (elevation above sea level). This is appropriate when the input digital elevation model (DEM ) is also using orthometric heights.
SRS
Optional
String
The coordinate system of the camera location as a well-known ID (WKID) or a definition string (well-known text [WKT]).
If a value for SRS is not explicitly defined, the spatial reference of the input oriented imagery dataset is assigned.
ImagePath
Required
String
The path to the image file. This can be a local path or a web-accessible URL. Images can be in JPEG, JPG, TIF, or MRF format.
Name
Optional
String
An alias name that identifies the image.
AcquisitionDate
Optional
Date
The date when the image was collected. The time of the image collection can also be included.
CameraHeading
Optional*
Numeric
The camera orientation of the first rotation around the z-axis of the camera. The unit is degrees. The direction of measurement for heading is in positive clockwise direction, where north is defined as zero degrees.
When the image orientation is unknown, -999 is used.
CameraPitch
Optional*
Numeric
The camera orientation of the second rotation around the x-axis of the camera. The unit is degrees. The direction of measurement for pitch is in positive counterclockwise direction.
The CameraPitch is zero degrees when the camera is facing straight down to the ground. The valid range of CameraPitch values is from 0 to 180 degrees. CameraPitch is 180 degrees for a camera facing straight up, and 90 degrees for a camera facing horizontally.
CameraRoll
Optional*
Numeric
The camera orientation of the final rotation around the z-axis of the camera in the positive clockwise direction. The unit is degrees. Valid values range from -90 to 90.
If the camera is pointed toward the horizon and the rows of the image are parallel with the horizon, the value of CameraRoll is 0. If the image (rows) is rotated by 90 degrees clockwise, the value of CameraRoll is 90.
CameraHeight
Optional
Numeric
The height of the camera above the ground. It is used to determine the visible extent of the image in which large values result in a greater view extent. The unit is meters. Values assigned must be greater than zero.
If the Z field value is not specified, the camera height is determined based on this field.
HorizontalFieldOfView
Optional
Numeric
The camera’s field of view in a horizontal direction. The unit is degrees. The valid values range from 0 through 360.
VerticalFieldOfView
Optional
Numeric
The camera’s field of view in the vertical direction. The unit is degrees. The valid values range from 0 through 180.
NearDistance
Optional
Numeric
The nearest usable distance of the imagery from the camera position. This value determines the near plane of the visible frustum in a 3D scene. The unit is meters.
FarDistance
Optional
Numeric
The farthest usable distance of the imagery from the camera position. This value determines the far plane of the visible frustum. The intersection of the frustum far plane with the ground defines the footprint, which is used to determine whether an image is returned when you click the map. The unit is meters. Values must be greater than zero.
CameraOffset
Optional
String
A pair of values, X, Y,separated by a semicolon.
These values represent the offset between the following:
  • The actual camera location
  • The feature point
Specifying CameraOffset reduces the search radius of the image from the camera location, as it brings the feature point closer to the image center.
The CameraOffset values must be in the same coordinate system as the oriented imagery dataset.
CameraOrientation
Optional
String
Detailed camera orientation parameters are stored as a pipe-separated string. This field provides support for more accurate image-to-ground and ground-to-image transformations.
OrientedImageryType
Optional
String
The imagery type is specified from the following:
  • Horizontal—Images where the exposure is approximately parallel to the ground and pointed to the horizon.
  • Oblique—Images where the exposure is at an angle (at about 45 degrees) to the ground so the sides of objects can be seen.
  • Nadir—Images where the exposure is nearly perpendicular to the ground and looking straight down. Only the top of objects can be seen.
  • 360—Images taken using specialized cameras that provide 360-degree spherical surround views.
  • Inspection—Close-up images of assets (less than 5 meters from the camera).
  • AerialFrameVideo—Video captured by a drone or aircraft with the camera pointing downward towards the ground.
  • TerrestrialFrameVideo—Video captured using handheld devices such as dashboard cameras.
  • Terrestrial360Video—A 360-degree video captured using devices such as GoPro or Insta360.
ImageRotation
Optional
Numeric
The orientation of the camera in degrees relative to the scene when the image was captured. The valid values range from -360 through 360. The value is used to rotate the view of the image in the oriented imagery viewer to ensure the top of the image is up.
OrientationAccuracy
Optional
String
Accuracy is defined as a string of eight semicolon delimited values that define the standard deviation of each value in the following order: Camera location in XY direction; Camera Z; Camera Heading; Camera Pitch; Camera Roll; Near distance; Far distance; Elevation.
All distances are defined in meters. All angles are defined in degrees. If a value is unknown, that value can be excluded. However, this may result in the accuracy computed being higher than the actual value.
For example, if the GPS has a +/- 10 meters RMS in x, y-coordinates and +/- 20 meters in height, the orientation accuracy value is 10;20.
The typical value for a vehicle mounted consumer camera is 15;10;5;5;5;0;0;1.
The typical value for a 360 camera with autoleveling (for example, GoPro or Insta360) is 15;0.2;0.5;0.5;0.5;0;0;1.
The typical value for a Drone imagery without Real Time Kinematic (RTK) and standard gimble is 5;10;2;2;2;0;0;1.
The typical value for oblique imagery following aerial triangulation is 0.01;0.02;0.001;0.001;0.001;0;0;1.
The values provided above are intended for reference only and should not be treated as absolute measurements. To ensure precise orientation accuracy parameters, the values should be taken directly from the system that captured the imagery.
For aerial imagery, these parameters are typically available in the Aerial Triangulation results, if that process has been completed.
For systems that record GPS‑based positional information, the GPS accuracy details should be supplied as part of the dataset.
Matrix
Optional*
String
The row-wise sorted rotation matrix that defines the transformation from image space to map space, specified as nine floating-point values, delimited by semicolons.
Period or full-stop must be the decimal separator for all the values.
Omega
Optional*
Numeric
The rotational angle of the camera's x-axis. The unit is decimal degrees.
Phi
Optional*
Numeric
The rotational angle of the camera's y-axis. The unit is decimal degrees.
Kappa
Optional*
Numeric
The rotational angle of the camera's z-axis. The unit is decimal degrees.
FocalLength
Optional*
Numeric
The focal length of the camera lens. The unit can be microns, millimeters, or pixels.
PrincipalX
Optional
Numeric
The x-coordinate of the principal point of the autocollimation. The unit must be the same as the unit used for FocalLength. By default, the value is zero.
PrincipalY
Optional
Numeric
The y-coordinate of the principal point of the autocollimation. The unit must be the same as the unit used for FocalLength. By default, the value is zero.
Radial
Optional
String
The radial distortion is specified as a set of three semicolon-delimited coefficients, such as 0;0;0 for K1;K2;K3. The coupling unit is the same as the unit specified for FocalLength.
A common approach in computer vision applications is to provide coefficients without mentioning the coupling unit. In such cases, use the following equations to convert the coefficients: f is the FocalLength value and K1_cv, K2_cv, and K3_cv are the computer vision parameters:
\(K1 \space = \space K1\_cv/(f \space * \space f)\)
\(K2 \space = \space K2\_cv/(f \space * \space f \space * \space f * \space f)\)
\(K3 \space = \space K3\_cv/(f \space * \space f \space * \space f \space * \space f \space * \space f \space * \space f)\)
Tangential
Optional
String
The tangential distortion is specified as a set of two semicolon-delimited coefficients, such as 0;0 for P1;P2. The coupling unit is the same as the unit used for FocalLength.
A common approach in computer vision applications is to provide coefficients without mentioning the coupling unit. In such cases, use the following equations to convert the coefficients. f is the FocalLength value and P1_cv and P2_cv are the computer vision parameters.
\(P1 \space = \space P2\_cv/f\)
\(P2 \space = \space -P1\_cv/f\)
A0,A1,A2
B0,B1,B2
Optional*
Numeric
The coefficient of the affine transformation that establishes a relationship between the sensor space and image space. The direction is from ground to image.
A0, A1, and A2 represent the translation in x direction.
B0, B1, and B2 represent the translation in y direction.
If the values are not provided, use the following equations to compute the values :
\(A0 \space = \space (Width \space of \space the \space Image/2)-0.5\)
\(A1 \space = \space 1\)
\(A2 \space = \space 0\)
\(B0 \space = \space (Height \space of \space the \space Image/2)-0.5\)
\(B1 \space = \space 0\)
\(B2 \space = \space -1\)
SequenceOrder
Optional
String/Numeric
The field stores a unique sequence of numbers or strings that drives sequential navigation.
OffsetFromStart
Optional
Double
The field defines the time offset, in seconds, between the first and last frame.
Optional*—The camera's Exterior Orientation in an oriented imagery dataset is determined by the CameraHeading, CameraPitch, and CameraRoll values.
If CameraHeading, CameraPitch, and CameraRoll are not explicitly defined, but the value for Matrix is defined, the missing field values are computed from the Matrix value.
If the values for Omega, Phi, and Kappa are defined, the values for Matrix, CameraHeading, CameraPitch, and CameraRoll will be computed. It is mandatory to follow the sequence Omega, Phi, and Kappa when specifying the values.
Rotation matrix computation logic
Optional*—The defined FocalLength value will be used only if the affine values (A0,A1,A2 and B0,B1,B2) are also defined. Otherwise, FocalLength will be computed in pixels from the image size and camera field of views.
Recommendations
Oriented imagery supports both approximate and highly precise camera orientations. While many metadata fields are optional, certain fields become essential when higher accuracy is required. These are described below.
  • Minimum required fields—To load an image into the viewer, the only mandatory fields in an oriented imagery dataset are the camera X, Y location and ImagePath. All other required fields are assigned default values as defined in the oriented imagery dataset.
    The default value for these fields are defined based on the imagery category selected for the first set of images added to the oriented imagery. The imagery categories are Horizonal, Oblique, Nadir, Inspection, and 360 imagery. These defaults are approximations and support general visualization but may not provide suitable world-to-image transformations. For example, with horizontal imagery, the default CameraPitch field is set to 90, which is only an approximation. It the CameraPitch value is known, it should be defined.
    Oriented Imagery Dataset Properties pane
  • Improving accuracy—To define the viewing frustum and footprint for each image, the following fields are used. They should be defined with suitable accuracy.
      • CameraHeading, CameraPitch, and CameraRoll define the camera view angles.
      • HorizontalFieldOfView and VerticalFieldOfView define the camera field of view.
      • CameraHeight, NearDistance, and FarDistance define relative height and suitable depth of field.
  • To enhance spatial accuracy, include the following fields:
      • Matrix—Enable more precise definition of camera orientation or it can be determined using Omega, Phi, and Kappa angles.
      • FocalLength
      • Affine values—A0,A1,A2 and B0,B1,B2
      • Radial and Tangential distortion coefficients
      • PrincipalX and PrincipalY coordinates
