Introduction to survey-based positioning data
Available for an ArcGIS organization licensed with the ArcGIS IPS extension.
Indoor positioning data can be generated using survey data collected with ArcGIS IPS Setup, available for iOS and Android devices. This approach requires planning and conducting an IPS survey, and is compatible with both Bluetooth-based and Wi-Fi-based deployments.
Contrary to this method, the survey-less positioning method does not require conducting an IPS survey and can be used with only Bluetooth-based indoor positioning system (IPS) deployments.
The survey-based indoor positioning workflow consists of two steps:
  1. Create recordings.
    Conduct a survey to collect radio signal data by recording the signal strength and other relevant parameters at various locations within the indoor environment.
  2. Generate an IPS positioning dataset.
    Use the created recordings to generate an IPS positioning dataset.
    If you are using an ArcGIS IPS Information Model from ArcGIS Pro 3.2 or earlier, it is recommended that you update to the latest version for enhanced functionality and support.
