Data types supported by a LAS dataset
The main data sources for LAS datasets are lidar data stored in LAS format files (*.las, *.zlas, and *.laz), and surface constraints stored in feature classes. zLAS and LAZ files are compressed versions of LAS files.
Lidar and point cloud data
General characteristics of point clouds include the following:
Lidar (light detection and ranging) point clouds stored in
.lasfile formatNot surface specific
Sampled to required nominal point spacing, varying from 1 to 3 feet (approximately 0.2 to 1 meters) depending on application
Every point contains attributes that are stored with the x,y,z data
Large quantities of point data
Photogrammetric point cloud data can also be stored in
.lasfiles
Compressed lidar formats
Two compressed lidar formats are supported in ArcGIS Pro: *.zlas and *.laz files. They are both losslessly compressed version of a LAS file. Compressed lidar formats are optimized versions of LAS files, which is useful for archiving, sharing, and direct use in ArcGIS Pro. Compressed lidar formats files are much smaller and much easier to share over networks, than regular LAS.
General characteristics for ZLAS format include the following:
You can add
*.zlasfiles to a LAS dataset using the LAS dataset properties dialog or by using the Create LAS Dataset geoprocessing tool.You can see individual
*.zlasfiles in the Catalog pane, and drag and drop them into a map or scene in ArcGIS Pro.A spatial index and statistics are generated for
*.zlasfiles when they are created. They are embedded into the*.zlasfiles and improve overall performance and usability. LAS datasets referencing*.zlasfiles will automatically use the statistics available for those files.A pyramid can be built for a LAS dataset referencing
*.zlasfiles.You can run geoprocessing tools to create derivative products from a LAS dataset referencing a
*.zlasfiles or on individual*.zlasfiles.You can edit class codes and class flags from a LAS dataset referencing
General characteristics for LAZ format include the following:
You can add
*.lazfiles to a LAS dataset using the LAS dataset properties dialog box or by using the LAS dataset properties dialog and the Create LAS Dataset geoprocessing tool..You cannot see individual
*.lazfiles in the Catalog pane, nor can you drag them to a map or scene in ArcGIS Pro. They must be added to a LAS dataset to be used in ArcGIS Pro.You can calculate statistics for a LAS dataset and its
referenced *.lazfiles to understand what class codes and other attributes that are available in the*.lazfiles.A spatial index is created for
*.lazfiles when statistics are calculated.A pyramid can be built for a LAS dataset referencing
*.lazfiles.You can run geoprocessing tools to create derivative products from a LAS dataset referencing a
*.lazfile.You can not edit class codes and class flags from a LAS dataset referencing
*.lazfiles.
Surface constraints
Surface constraints are surface features stored in geodatabase feature classes, which are usually derived from a remote sensing technique such as photogrammetry.
Characteristics of photogrammetrically derived breaklines include the following:
Surface-specific breaks in slope along linear features
Natural landforms (for example, ridges and valleys)
Terrain features resulting from earthworks (for example, bulldozed)
Lake shorelines, creeks, or river shorelines
Edge of road pavement
Delineation of void areas (typically obscured by vegetation)
Minimal attribution
Typically moderate quantities
Characteristics of GPS points include the following:
Irregularly spaced
May or may not represent surface-specific peaks and pits
Used for control, QA, and benchmarking other data
Property boundary control points
Potentially significant attribution per point
Typically small quantities
The following table describes the types of surface constraints that can be used.
Surface constraint type |
Feature class |
Z-value source in the feature class |
Example data |
Points (x,y,z locations) |
Point feature class |
Can be either of the following:
Polygon feature class |
or
Shoreline delineation |
Breaklines (hard or soft) |
Line feature class |
Lake shoreline |
Clipping polygons (hard or soft) |
Study area boundary |
Erase polygons (hard or soft) |
Replace polygons (hard or soft) |
Water bodies |
