Create a template for an LRS length data product
Available with the Linear Referencing license.
You can use the Data Product Designer wizard to create a template for a linear referencing system (LRS) length data product.
An LRS length data product is used to calculate the length of routes based on their characteristics. The following table is an example of an LRS length data product that computes length of pipes in different materials summarized by line name:
  • Summary field: Pipeline Name
  • Length fields: Steel, Plastic, Cast/Wrought Iron, Ductile Iron, Copper, and Other
Pipeline Name Steel Plastic Cast/Wrought Iron Ductile Iron Copper Other
Dripping Springs to Smithville 57685.399 2782.144 30466.520 105.835 5313.148 205.972
Smithville to San Antonio Pressure System 38100.377 2774.152 30084.713 106.712 5506.429 112.218
Smithville to Houston National 68750.141 2778.091 30152.803 113.810 5763.907 171.440
Houston National to West Montgomery 9891.025 1013.462 20014.545 69.013 2275.384 26.855
Toboso Flat to Wink 22570.633 1662.397 23085.910 182.339 3350.644 55.359
Wink to Crane 8810.257 792.611 19934.529 103.849 4029.958 104.295
Crane to Puckett 49052.482 1093.583 29883.968 99.403 2938.018 105.951
Puckett to Middle Valley 84739.194 2119.244 41182.485 205.975 6391.573 322.594
Turner to Brandenberger 66 Ranch 9295.227 598.028 18493.245 38.996 1998.912 56.421
Gathering Backbone Line 49672.684 2649.184 26583.385 139.586 5999.484 189.400
Other types of LRS length data products that you can configure include the following:
  • Length of types of pipe systems, such as on-shore transmission, on-shore gathering, and so on, summarized by installation year
  • Length of leak report summarized by pipeline name and status code
  • Length of categories of pipe diameters and pipe materials summarized by pipe systems
An LRS length data product is used to calculate the length of routes based on their characteristics. The following table is an example of an LRS length data product that computes mileage of urban roads and rural roads summarized by counties and pavement conditions.
  • Summary fields: County and Pavement
  • Length fields: Urban Roads and Rural Roads
County
Pavement
Urban Roads
Rural Roads
Crawford
Paved
235.533
13.852
Unpaved
6.029
5.487
Dubois
Paved
44.496
122.724
Unpaved
13.153
55.692
Harrison
Paved
104.002
82.520
Unpaved
19.638
46.776
Pike
Paved
633.968
34.25
Unpaved
41.576
3.040
Perry
Paved
260.674
0.000
Unpaved
20.030
0.016
Spencer
Paved
103.373
1.031
Unpaved
9.655
0.000
Warrick
Paved
422.927
208.069
Unpaved
55.608
102.700
  • Mileage of types of road surfaces, such as bitumen, asphalt, gravel, concrete, and so on, summarized by functional class
  • Mileage of maintained public roads in each county, summarized by jurisdiction
  • Lane miles and daily Vehicle Miles Traveled (VMT) by urban area
In this workflow, you'll learn how to create a template to produce an LRS length data product similar to the one shown in the table above.
Choose an LRS data product type
The first step in the Data Product Designer wizard is to specify the data product type.
To specify the length data product type, complete the following steps:
  1. Start ArcGIS Pro and open a project with LRS data in the map.
  2. On the Linear Referencing tab, in the Data Products group, click Data Product Designer .
    The Choose an LRS data product type page of the Data Product Designer wizard appears, and the default Data Product Type value is Length.
  3. Click Next.
    The Set template properties page appears.
To set the template properties, complete the following steps:
  1. Provide a template name.
    By default, the template is saved in the project folder. Optionally, browse to a different location, provide a name for the template, and click OK.
  2. Click the Network drop-down arrow and choose a network.
    This network is used to calculate the length of the routes.
    This network is used to calculate the length of the roads.
  3. Optionally, provide a description.
  4. Optionally, click Preview to open the canvas.
    The canvas formats the information provided in the Data Product Designer wizard.
    Template properties in the canvas
  5. Click Next.
Add summary fields
The next step in producing the LRS data template is to select a summary layer and summary fields. The LRS length data product is summarized based on unique values in the summary layer. You can configure multiple summary layers and summary fields. The summary layers are arranged and divided by levels based on their spatial relationships.
For this example, you can configure a pipe system layer as level one, and a pipeline layer as level two. The LRS length data product summarizes the length of each pipeline in each pipe system.
For this example, you can configure a county boundary layer as level one, and a pavement condition layer as level two. The LRS length data product summarizes the length of paved and unpaved roads in each county.
This step in the process is optional. If you don't want to add summary fields to the template, click Next to proceed.
To set the template summary fields, complete the following steps:
  1. Click Add to add a summary level.
  2. Click the Summary Layer drop-down arrow and choose a summary layer.
    This layer can be a polygon feature class, a line event registered to the network specified in the second page, or the network itself. This layer must be in the same geodatabase or feature service and have the same coordinate system as the specified network.
    For this example, Engineering Network is the summary layer for the first level.
  3. Click the Field drop-down arrow and choose a summary field.
    For this example, Line Name is the summary field for the Engineering Network layer.
    After you choose a summary field, the Display Value Map section shows the unique values in the summary field. You can edit the Display Value column in the table. The LRS length data product only calculates route length for values in the Display Value Map section.
    The Add summary fields page
  4. Provide a name for the summary level in the Name in Table text box.
    For this example, the level name is Pipeline Name.
  5. Optionally, click the Filter Expression drop-down arrow and provide an expression to filter display values in the Display Value Map section.
    For this example, the pipelines that are gathering field pipes are chosen. Only the length of the routes in these pipelines will be calculated.
    Display values are filtered using an expression in the Add summary fields page
    Summary fields in the canvas
  6. Optionally, check the Summarize unclassified values check box to summarize length that is not included by the values in the Display Value Map.
    The summary field returns an additional value, Unclassified.
    By default, the Summarize unclassified values check box is not checked. This check box applies to all summary layers.
    For this example, the Summarize unclassified values check box remains not checked.
  7. If you're adding multiple summary levels, repeat the previous steps for each level.
  8. Click Next.
    For this example, County Boundary is the summary layer for the first level.
    For this example, County Name is the summary field for the County Boundary layer.
    After you choose a summary field, the Display Value Map section shows the unique values in the summary field. You can edit the Display Value column in the table. The LRS length data product only calculates road length for values in the Display Value Map section.
    Roads clipped by county polygons
    For this example, the level name is County.
    For this example, the seven counties that belong to the Southeast category are chosen. Only the length of the roads that are clipped by these seven counties are calculated.
    Roads clipped by seven counties in the Southeast
    For this example, Pavement Condition is the summary layer for the second level, PSR is the summary field, and Pavement is the second level name. A filter applied to PSR generates two display values: Paved and Unpaved roads.
    As a result, the LRS length data product summarizes the length of paved and unpaved roads in each county.
    Multiple summary layers are set in the Add summary fields page
  8. Click Next.
Add length fields
After you select the summary layer, the next step is to add the length fields. The length fields form the columns that show the length of routes in the LRS length data product.
After you select the summary layer, the next step is to add the length fields. The length fields form the columns that show the length of roads in the LRS length data product.
The options for configuring length fields are Single Value and Unique Values. You can configure length fields one by one using the Single Value option and applying a filter to create categories, or you can use the Unique Values option to configure all the unique values needed as individual length fields.
This example uses Single Value to calculate the length of pipes in different materials because the data has more than one unique value that combines into one category. For example, the Steel field is a composite of the Bare Steel and Coated Steel fields. You'll configure them as one length field instead of individual fields.
This example uses Single Value to calculate the mileage of urban and rural roads because the data has four unique values that you can configure as two fields instead of four.
To set template length fields, complete the following steps:
  1. Click Add to add a length field.
  2. Click the Length Layer drop-down arrow and choose a length layer.
    This layer can be a line event registered to the network specified in the second page, or the network itself. This layer must be in the same geodatabase or feature service and have the same coordinate system as the specified network.
    For this example, line event Gathering Field Pipe is the first length layer.
  3. Click the Selection Method drop-down arrow and choose a selection method.
    • Single Value—Add a single length field.
    • Unique Values—Add multiple unique values for a selected length field, and each unique value becomes an individual field. This option only appears when a length layer is provided without a name or filter.
    If you chose Single Value, skip step 4 below. For this example, Single Value is used as the selection method with customized filters applied to the length field and the example continues at step 5 below.
  4. If you chose Unique Values, choose a field in the length layer from the pop-up window that appears and do the following:
    1. Choose the unique values by clicking the check boxes next to the values.
      Pop-up window to choose the field and unique values
    2. Optionally, change the name for each selected unique value.
      The name becomes the name for the length field when the unique values are added to the Data Product Designer wizard.
    3. Click Add to add the selected unique values as length fields.
      Each length field automatically has Single Value as the selection method, and a filter expression corresponding to the unique values.
      Unique values are added as length fields with the corresponding name and filter expression
      The Unique Values option also honors values in coded value domains and subtypes.
  5. Provide a name for this length field or update the existing names by clicking each cell.
    For this example, Steel is the name for the first length field.
  6. Optionally, click the Filter Expression drop-down arrow and provide an expression to filter the length fields.
    For this example, because the template is used to calculate length of pipes in different materials, the length fields are the unique values in the Material field. The first length field is named Steel, and a filter is applied to the Material field to select values that correspond to the steel category, such as bare steel and coated steel.
    The Add length fields page
  7. Optionally, check the Calculate row and column totals check box to calculate the total length value for the rows and columns in the data product.
    By default, the Calculate row and column totals check box is not checked. This check box applies to all length layers.
    For this example, the Calculate row and column totals check box remains not checked.
  8. If you're adding multiple length fields, repeat the previous steps for each field.
    For this example, the additional length fields are Plastic, Cast/Wrought Iron, Ductile Iron, Copper, and Other.
    Multiple length fields are set in the Add length fields page
    Length fields in the canvas
  9. Click Finish to save the template.
    For this example, line event CLEu_RurlUrbn is the first length layer.
    For this example, Urban Roads is the name for the first length field.
    For this example, because the template is used to calculate mileage of urban roads and rural roads, the first length field is named Urban Roads, and a filter is applied to the RuralUrban field to select values that correspond to the urban roads category.
    For this example, the second length field is called Rural Roads and a filter is applied to the RuralUrban field to select values that correspond to the rural roads category.
To view or edit an existing template, on the Set template properties page, click Browse for the template location next to the Template text box. You can choose a template from the project folder or from other locations.
You can use this template in the Generate LRS Data Product tool.
