Release locks through the LRS Locks table
Available with the Linear Referencing license.
Use the LRS Locks table to review and release line, route, and event locks.
Use the LRS Locks table to review and release route and event locks.
Tip:
You can also release locks with the Release Locks tool.
You can differentiate between the lock types by looking at the contents of the Event column. If a cell in the Event column contains a value, the lock is an event lock. If a cell in the Event column is blank, the lock is a route or line lock.
You can differentiate between the lock types by looking at the contents of the Event column. If a cell in the Event column contains a value, the lock is an event lock. If a cell in the Event column is blank, the lock is a route lock.
The following is an example of event and route locks in the LRS Locks table:
You can identify lock types in the LRS Locks table by user.
The numbers in the previous image correspond to the numbers in the following table:
| Number | Lock type |
| Route or line | |
| Event |
| Item | Lock type |
| Event | |
| Route |
Tools available in the LRS Locks table
The following table describes the tools available in the LRS Locks table:
Tool |
Tool name |
Tool description |
Selection |
Select All |
Selects all the records in the LRS Locks table and shows the selection on the map. |
Zoom To Selection |
Zooms to the routes associated with the highlighted locks on the map. |
Switch Selection |
Switches the selected rows. |
Clear Selection |
Clears any selected rows in the table. |
Copy Selection |
Copies the selected rows. |
Release Locks |
Release selected locks |
Releases the locks from the selected rows. This tool is enabled only when all the selected rows have their releasable status values set to Yes. |
Release all releasable locks |
Releases all the locks whose releasable status value is Yes. There is no need to select rows. |
Release highlighted locks |
Releases the locks from the highlighted rows. This tool is available only in Show Selected Records mode. This tool is enabled only when all the highlighted rows have their releasable status values set to Yes. |
Highlighted (available in Show Selected Records mode) |
Unselect Highlighted |
Removes the highlighted rows from the current selection set. |
Reselect Highlighted |
Updates the current selection set to highlighted rows (only). |
Switch Highlighted |
Switches the highlighted rows. |
Clear Highlighted |
Deselects the currently highlighted rows. |
Tools available when right-clicking a row |
Flash |
Flashes the route on the map. |
Zoom To Selection |
Zooms to the route on the map. |
Pan To Selection |
Pans (center) to the route on the map. |
Select/Unselect |
Selects or unselects the row in the table and on the map. |
Highlight/Unhighlight |
Highlights or unhighlights the row in the table and on the map. This tool is available only in Show Selected Records mode. |
Pop-up |
Shows the attributes for the route on the map. |
Release locks
You can release locks in the LRS Locks table if the Releasable column value is Yes.
The following table describes the releasable status values:
| Releasable status | Reason |
| Yes | The lock is owned by the user who is signed in (in any named version), and the route or event has not been edited. |
| On Post | The lock is owned by the user who is signed in (in any named version), and the route or event has been edited. |
| No | The lock is owned by another user. |
To release locks through the LRS Locks table, complete the following steps:
Start ArcGIS Pro and open a project with a linear referencing system (LRS) Network from a conflict prevention-enabled LRS.
On the Linear Referencing tab, in the Conflict Prevention group, click LRS Locks
to open the table.Optionally, filter the locks in the LRS Locks table using the available filters for the Network, User, Version, Event, and Line columns.
You can use the filters individually or in combination to show only the locks that meet these conditions.
Optionally, filter the locks in the LRS Locks table using the available filters for the Network, User, Version, Event, and Route columns.
To release locks, do one of the following:
To release one lock, select a row with the releasable status value of Yes and click Release Selected
.To release all locks with the releasable status value of Yes without selecting any rows, click Release All
The locks are released.
Impact of the user and version on releasable status
The releasable status in the LRS Locks table depends on the signed-in user and the named version being edited.
The following is an example of the LRS Locks table with user 22 signed in using Version2:
| Number | Description |
| 1 | The locks were acquired by user 22 using Version2, and their edits were saved, resulting in a releasable status value of On Post. |
| 2 | The locks were acquired by user 22 using Version2, and they didn't save any edits, resulting in a releasable status value of Yes. |
| 3 | The locks were acquired by user11 using Version1, and the signed-in user (user 22) didn't acquire the locks, resulting in a releasable status value of No. |
The following is an example of the LRS Locks table with user 11 signed in using Version1:
| 1 | The lock was acquired by user11 using Version1, and they didn't save any edits, resulting in a releasable status value of Yes. |
| 2 | The locks were acquired by user22 using Version2, and the signed-in user (user11) didn't acquire the locks, resulting in a releasable status value of No. |
