Reverse routes
Available with the Linear Referencing license.
During the lifespan of a pipeline or roadway, the direction of calibration of a route may need to be reversed as a result of calibration in the wrong direction or in preparation for a realignment that requires route calibration to be reversed.
Use the Reverse Route tool to reverse route calibration direction in a linear referencing system (LRS) Network. You can then reapply event behaviors to the reversed route. The Reverse Route tool updates calibration points along the reversed route and reverses the route direction.
Before using this tool to edit a feature service, you must share branch versioned LRS data as a web layer. If the feature service is not yet published, see Share as web layers. If you are using a file geodatabase LRS dataset, this tool provides limited functionality.
Beta:
You can use the ArcGIS Pro Assistant (Beta) to perform route reversal and to guide you through the workflow.
Reverse a route
To reverse a route, complete the following steps:
Start ArcGIS Pro and add the LRS Network feature classes to a map.
You can also open a map in which the LRS Network layer is present.
Zoom to the location where you want to reverse a route.
On the Linear Referencing tab, in the Route Editing group, click Reverse
.The Reverse Route pane appears.
Click the Network drop-down arrow and choose the LRS Network to which you want to reverse a route.
If the network is a nonline network, the Route Name or Route ID parameter appears in the pane.
If the network is a line network, the From Route Name and To Route Name parameters appear in the pane.
Provide an effective date for the route reversal by doing one of the following:
Double-click in the Effective Date text box to use today's date.
Provide the date in the Effective Date text box.
Click the Calendar
and choose a date.
Select a route to reverse by clicking Choose route from map
.If the network is a line network, click Choose route from map
and select the ending route on the map to populate the To Route Name parameter.If the From Route Name and To Route Name values in a line network are not the same, the routes spanned by the map selection are reversed.
Click Run.
The selected routes are reversed.
Route reversal scenarios
The following scenarios describe route reversal.
Route reversal with intermediate calibration points at equal distances
In the following example, Route 1 has a start measure of 0 and an end measure of 10 with intermediate calibration points at 2.5, 5, and 7.5:
After reversing the route, the start and end measures are reversed, and intermediate calibration measures are updated, but the location of calibration points remains unchanged:
Route reversal with disproportionate intermediate calibration points
In the following example, Route 1 has a start measure of 0 and an end measure of 10 with a disproportionate intermediate calibration point (8):
The start and end measures are reversed, and the intermediate calibration measure is updated from 8 to 2, but the location of the calibration point remains unchanged:
Route reversal on a line in a line network
Before route reversal, Route 1 has start and end measures of 0 and 10, Route 2 has start and end measures of 15 and 25, and Route 3 has start and end measures of 30 and 40. The line order for the routes is 100, 200, and 300, respectively.
In the following example, three routes that are present on a line (Line A) in a line network are reversed:
After the reversal, the start and end measures are updated, but the location of the calibration points remains unchanged:
After the reversal, each of the routes has the same start and end measures but in the opposite direction. The line order remains the same before and after the route reversal.
