Set a time filter
Available with the Linear Referencing license.
Use the Set Time Filter tool to configure the time view for LRS-managed layers. You can set the time view to a specific date or a date range for time-enabled LRS layers.
Before using the Set Time Filter tool, you must first enable time for an LRS layer or for all LRS layers in a map.
To configure a time filter for a map, complete the following steps:
  1. Start ArcGIS Pro and open a project with LRS data in the map.
  2. On the Linear Referencing tab, in the Tools group, click Set Time Filter .
    Tip:
    If LRS layers in a feature service are published without time enabled, both Enable Time and Set Time Filter are inactive on the tab.
    The Set Time Filter dialog box appears.
    Set Time Filter dialog box, with the Use current system date and time option chosen
  3. Configure one of the following options:
    • Choose the Use current system date and time option to filter time-enabled LRS layers using the current system date and time.
    • Choose the Specific date range option and specify a start date and end date to filter time-enabled LRS layers.
    • Choose the Clear date range option to clear the time filter.
    Set Time Filter dialog box, with the Specific date range option chosen
  4. Click Apply to update the time filter in the map.
    You can also set the time view on the map to the system date and time by checking the Set LRS layers in maps to the current date and time check box on the Options dialog box. When this option is checked, the current date and time are set on the map when the project is opened.
