Data quality management capabilities
The parcel fabric provides a variety of flexible data quality management capabilities in ArcGIS Pro. These capabilities include the following:
Geodatabase topology
Attribute rules
Least-squares adjustment
Configured data quality layers
Gap and overlap detection
Disconnected and duplicate point detection
These capabilities are configurable and can be used in quality-driven workflows to evaluate and fix common data quality issues in parcel data.
A parcel fabric is created with a geodatabase topology containing a set of default topology rules. These topology rules define and enforce the topological relationships between parcel features.
You can configure additional topology rules for topological relationships between parcel feature classes and for topological relationships between parcel feature classes and other feature classes. For example, you can add a rule that requires a parcel type to be completely contained by another parcel type.
Topology rules are validated in the Error Inspector pane to identify rule violations. Rule errors are displayed as error features and can be fixed in the map.
One advantage of a geodatabase topology is its ability to model different behaviors for parcel types using different sets of rules. Rule violations can be viewed and fixed in the map using error features and predefined topological fixes.
Validating a topology modifies the data by performing cracking and clustering.
Learn more about parcel fabric geodatabase topology
Attribute rules
The parcel fabric is created with a set of default attribute rules. Attribute rules are geodatabase rules that can be used to automatically populate attributes, constrain invalid edits during edit operations, and evaluate data.
Optional preconfigured parcel fabric attribute rules are also available for import. You can configure your own attribute rules in addition to the default and optional parcel fabric rules.
Learn more about parcel fabric attribute rules
Attribute rules are configured using Arcade, which is a flexible scripting language that allows you to build custom expressions that reference both feature attributes and geometries. For example, you can configure attribute rules to perform batch field calculations, prevent incorrect edits from being saved, and evaluate data.
Learn more about evaluating parcel fabric attribute rules
You can run a least-squares adjustment on a selection of parcels to evaluate and improve spatial accuracy. For the most reliable results, only run a least-squares adjustment on parcels with lines that have record-accurate COGO dimensions.
You can use a least-squares adjustment in two ways to evaluate and improve spatial accuracy:
Perform a consistency check on a parcel network of COGO dimensions to detect possible mistakes or outliers. Point locations are not updated.
Use control points in a weighted adjustment to estimate more accurate coordinates for points. Point locations are updated.
A least-squares adjustment requires good estimation of a-priori accuracies and may require several runs before the chi-test passes. The adjustment will not return meaningful results when run on parcel lines that have inversed dimensions (dimensions generated from shape geometry).
Currently, the parcel fabric least-squares adjustment cannot be used for coordinate-based cadastres.
Learn more about running a least-squares adjustment
Configured data quality layers are available for parcel fabric feature classes. Configured data quality layers are map visualization layers that have been specifically configured to show potential data quality issues in the parcel fabric. Examples of issues are lines that are too short and lines with too many vertices. You can use configured data quality layers to quickly identify erroneous features in parcel fabric feature layers.
The following configured data quality layers are available:
Distance mismatch—Displays parcel lines with COGO distances that do not match their shape lengths.
Too short—Displays parcel lines with shape lengths that are shorter than the configured tolerance.
Line vertices—Displays parcel lines with vertices.
Vertices—Displays parcel polygons with vertices.
Learn more about configured data quality layers
Gaps and overlaps
Use the Highlight command
in the Gaps and Overlaps group on the Quality tab to find gaps and overlaps between parcels in a parcel type. Gaps and overlaps are highlighted in the current map extent.
To detect gaps and overlaps between all parcel polygon layers in the map use the Find Gaps And Overlaps geoprocessing tool.
Learn more about detecting gaps and overlaps
Use the Find Adjacent Parcel Points geoprocessing tool to find parcel points that are on top of each other (coincident) or closer to each other than a specified tolerance.
Use the Find Disconnected Parcel Points geoprocessing tool to find parcel points that are not connected to any connection lines or parcel lines.
