Export a named trace configuration
The Export Trace Configurations tool allows you to export one or more named trace configurations from a trace network to a .json file for sharing across multiple trace networks.
Requirements
  • The input trace network must be version 2 or later.
When working with an enterprise geodatabase, the following apply:
  • The Input Trace Network parameter value must be from a trace network service.
Follow these steps to export named trace configurations from a trace network:
  1. On the Analysis tab, in the Geoprocessing group, click Tools to open the Geoprocessing pane.
  2. In the Geoprocessing pane, search for and select Export Trace Configurations.
    The tool can be found in the Trace Configuration toolset of the Trace Network toolbox.
  3. For Input Trace Network, specify a trace network.
  4. For Trace Configuration, select one or more named trace configurations from the list provided.
  5. Click Run.
The selected named trace configurations are exported from the Input Trace Network to the specified output .json file. For an example output, see Export Trace Configurations.
