View Run Data Checks validation history
Available with Data Reviewer license.
A history of the automated validation performed on features using the Run Data Checks tool in a map allows you to manage pending and active validations, identify rules that have failed to run properly, and review previous configurations.
Validation history view
You can review the results of current or previous Run Data Checks validations using the History button on the Manage Quality tab in the Automated Review group.
Tip:
You can double-click results in the History drop-down menu to repopulate the attribute fields in the Run Data Checks pane.
History drop-down menu results
The numbers in the following table correspond to the numbers in the image above:
Number
Validation is pending.
Validation was canceled before running the tool.
Validation is in progress.
Validation is complete with errors detected.
Validation is complete with no errors detected.
6
Validation was canceled.
7
Cancel validation that is in progress or pending.
Export Run Data Checks into Attribute Rules
You can export Run Data Checks results to a .csv file to use as validation attribute rules. The .csv file is named after the Feature class selected in the Input Feature parameter.
To export Run Data Checks results to use as validation attribute rules, complete the following steps:
  1. Start ArcGIS Pro.
  2. Click the Edit tab, and in the Data Reviewer group, click Manage Quality .
  3. In the Automated Review group, click the Run Data Checks drop-down menu and select the check that you want to use to review your data for errors.
    The Run Data Check pane appears.
  4. Complete the required check parameters and click Run.
    The check runs on the data and reports any errors that are found.
  5. In the Automated Review group, click the History drop-down menu and click a result.
    Tip:
    Press Shift while clicking two or more results to select a range of results, or click results while pressing the Ctrl key to select multiple results.
  6. Right-click the selection and click Export to attribute rules .
    The Select Output .csv Location dialog box appears.
  7. Browse to the location where you want to save the rule configuration.
    If the .csv file is saved in the same location as .csv files with the same name, the files will be overwritten.
  8. Click OK.
    A notification appears stating the number of checks and .csv files exported.
Once the .csv file is created, to add the rule as a validation attribute rule, complete the following steps:
  1. Ensure that Global IDs and Editor Tracking are enabled.
    1. In the Catalog pane, right-click the feature class that you want to create a validation attribute rule on and click Properties.
      The Feature Class Properties dialog box appears.
    2. Click Manage.
    3. Ensure that the Global IDs and Editor Tracking check boxes are checked.
  2. In the Contents pane, right-click a feature layer that you want to add your Run Data Checks rule to, and point to Data Design and click Attribute Rules.
    The Attribute Rules view appears for the selected feature layer.
  3. In the Import/Export group, click Import Rules .
    The Import Rules dialog box appears.
  4. Browse to the location where you saved the .csv file and choose it.
    If the .csv file is not appearing as expected, click Refresh .
  5. Click OK.
  6. The rule appears under the Validation tab.
  7. In the Manage Edits group, click Save .
