Slice a multipatch or 3D object
The Slice Multipatch tool splits a multipatch or 3D object feature at a specified location using a horizontal or a vertical cutting plane. This tool is available in the Modify Features pane when the active view is a 3D scene.
You can choose to keep the sliced features with openings or generate closed features.
To slice a multipatch or 3D object feature, complete the following steps:
  1. On the Edit tab, in the Features group, click Modify .
    The Modify Features pane appears.
  2. Expand Divide and click Slice Multipatch .
    The tool opens in the pane.
  3. Click Active Select , and select the multipatch or 3D object feature you want to slice.
    The slice multipatch toolbar appears at the bottom of the scene.
    Slice Multipatch toolbar
    By default, the move and rotate alignment tools are turned on. You can use them together or turn them on or off individually as you align the cutting plane.
  4. To create a horizontal cutting plane, do the following:
    1. Click Horizontal
    2. Click the multipatch or 3D object feature where you want to locate the horizontal cutting plane.
    The active alignment tools appear at the location you clicked, and the feature renders with two colors that preview where the cutting plane is slicing the feature.
  5. To create a vertical cutting plane, do the following:
    1. Click Vertical.
    2. Click the multipatch or 3D object feature where you want to locate the vertical cutting plane.
    3. Move the pointer vertically and click the feature again to define the axis of the cutting plane.
  6. To adjust the angle and pitch of the cutting plane, click and drag the pointer along one of the circular controls on the rotate tool.
  7. To move the cutting plane, click and drag the conical anchor that appears on the move tool axis.
  8. Choose to keep the resulting open features or generate the missing faces.
    • Solid—Automatically generates the resulting missing faces and creates close features. This option only works for multipatch or 3D object features that completely enclose a volume of space before you slice it.
      To evaluate or enclose a multipatch or 3D object feature, use the following geoprocessing tools:
    • Hollow— Preserves the two features as they are.
  9. Click Slice.
