Split lines into COGO lines
The Split Into COGO Lines tool
creates two-point COGO lines and arcs by splitting features at each vertex. You can split the selected features or preserve them and create the split lines on a specified COGO-enabled layer. This tool is available in the Modify Features pane.
To split lines into COGO lines, complete the following steps:
Click the ribbon Edit tab. In the Corrections group, click Ground To Grid, and verify your ground to grid settings.
On the ribbon Edit tab, click Modify
in the Features group.The Modify Features pane appears.
Click the Split Into COGO Lines tool
.To find the tool, expand COGO, or type
COGOin the Search text box.The tool opens and the Select tool
automatically runs.Select the line features to be split into COGO two-point lines and arcs.
The selected features appear in the selection view.
To refine the selection, right-click a feature in the selection view, and click Unselect
or Only Select This
.Tip:
If a line feature does not exist, you can create one using a feature template. When you click Finish
or press F2, the tool uses it as the current selection.If features are currently selected, the selection tool displays Change the selection.
Check or uncheck the Use Template check box.
Checked
Preserve the selected features and create COGO line features on the specified layer. Click the layer drop-down arrow and choose a layer with a COGO-enabled data source.
Unchecked
Modify the selected features.
Check or uncheck the Split lines with existing COGO attributes check box.
Checked
Split lines and override existing COGO attributes.
Unchecked
Don't split lines containing COGO attributes and preserve existing values.
Click Split.
