Change the appearance of a voxel layer
You can adjust the display and appearance of a voxel layer on the Voxel Layer tab set. You can change the offset, vertical exaggeration, the variable used, and the symbology as well as manipulate lighting options on your voxel layer.
Elevation
When a voxel layer is added to a local scene, default elevation properties are applied to make the differences in height more apparent. These properties include Offset and Vertical Exaggeration. The default value given to vertically exaggerate the height of the voxel layer is proportional to the x,y extent of the layer. When vertically exaggerating a voxel layer, its height is scaled by the value you set for the Vertical Exaggeration property.
The default method of voxel exaggeration From voxel dataset origin, scales only the voxels themselves and not the space between the coordinate system and the voxel dataset origin. It is equivalent to translating the voxel dataset to the coordinate system origin, applying the vertical exaggeration scaling, and then translating the voxel dataset origin back to its correct position. The ground elevation surface layer and other layer types in ArcGIS Pro do not apply vertical exaggeration in this manner as they multiply all z positions by the exaggeration scaling factor. To exaggerate a voxel layer in the same way as the terrain and other layers, you can change the exaggeration mode for the voxel layer. For example, if a voxel layer represents a geological formation and you want to show it in the same scene with an exaggerated borehole feature layer, you can change the voxel layer exaggeration mode to Z-coordinates.
For XYZ and XYZT volumes where Z values are equally spaced (regular), the default method of voxel exaggeration does not work well if the voxel dataset origin is further from elevation 0 than the last voxel. In this case, a positive exaggeration will be towards elevation 0. You can check the voxel dataset origin on the Source tab of the Layer Properties dialog box. If the origin is not closest to 0 or the Z values are irregular, you can use the regularize z Python script to flip the Z values.
Set vertical exaggeration
To set the vertical exaggeration of a voxel layer, follow these steps:
Select a voxel layer in the Contents pane.
Click the Voxel Layer tab set.
Set the Offset and Vertical Exaggeration properties in the Elevation group.
Optionally, change the Exaggeration mode property to match the feature layer's z-coordinate exaggeration mode on the Layer Properties dialog box.
Lighting
Use lighting options with a voxel layer to improve depth perception in 3D visualization. Lighting options are important if a voxel layer contains many different cubes as unique values or if you are visualizing an isosurface. You can define the Diffuse property to make the voxel layer appear more matte or the Specular property to make the voxel layer appear glossier. Depending on the position of the light source, the appearance of the voxel layer changes.
Set lighting options
To set the lighting options for a voxel layer, follow these steps:
Set the Diffuse
and Specular
properties using the slider, or type the number.
