glTF markers
The GL Transmission Format (.glTF file) is an industry-standard interchange format for the transport of 3D models. Binary GL Transmission Format (.glb) files are binary versions of a glTF file that also include embedded assets such as textures.
Learn more about the glTF specification
glTF markers can contain multiple levels of detail (LODs) to manage their display in an efficient and sensible way across a range of view distances. This scalability means that when the marker is in the distance in a scene, it draws with less complexity than when it is drawn in the foreground, nearer to the viewer.
glTF markers can include material properties such as shininess, roughness, or metalness. This gives models a distinctive sense of realism that can't be achieved with only flat color.
Supported features from the glTF specification
The currently supported features from the glTF specification are as follows:
Full-node hierarchies, including node transformations and mesh instancing.
The MSFT_lod glTF extension is supported, but only node-based LODs, not material-based LODs. MSFT_lod can only appear in the first node of a scene. If it appears elsewhere, all occurrences of MSFT_lod are ignored.
Primitive geometry types:
TRIANGLE,TRIANGLE_STRIP, andTRIANGLE_FAN.All vertex attributes and methods of specifying attributes using buffers, bufferViews, and accessors, except as otherwise noted.
GLB (binary glTF).
Node transform animation. One animation per animated property.
Morph target animation (position, normal, uv, tangent, color). One animation per animated property.
Metallic-Roughness materials.
Normal maps.
Occlusion maps.
Emissive maps.
Vertex colors.
UV clamping.
UV mirroring.
Specular glossiness defined by the KHR_Materials_pbrSpecularGlossiness extension.
Textures using Basis Universal supercompression format, defined by the KHR_texture_basisu extension.
Advanced compression for mesh geometry, defined by the KHR_draco_mesh_compression extension.
The index of refraction (IOR) for materials, to render transparent and refractive surfaces like glass, water, or gemstones, as defined by the KHR_materials_ior extension.
Specular reflection to show a mirror-like reflection of light from a surface, as defined by the KHR_materials_specular extension.
Simulation of a thin, transparent, glossy layer on a base material to represent car paint, varnished wood, or coated metals, as defined by the KHR_materials_clearcoat extension.
Realistic rendering of transparent materials by simulating light transmission through a surface, as defined by the KHR_materials_transmission extension.
The rendering engine must be set to DirectX12 or Vulkan to use these extensions:
Unsupported features from the glTF specification
The features that are not currently supported from the glTF specification are as follows:
The glTF document scene must be set to a specific scene, or there must be exactly one scene in the glTF document.
All glTF extensions except those noted above.
Skins.
POINTS,LINES,LINE_LOOP, andLINE_STRIP.Cameras.
Multiple UV sets.
Sparse accessors.
