Work with bookmarks in the Bookmarks pane
Bookmarks can identify the map or scene where they were created. The Bookmarks pane lists the bookmarks by map for the current project with the active map or scene view's bookmarks on top. All other map names are listed alphabetically beneath. Any bookmark in your current project can be managed using the Bookmarks pane. Hover over a bookmark to give focus to it and access management buttons for the state of your bookmark, such as navigation, update, and removal. Right-click the containing map or scene name to manage all of the associated bookmarks at one time.
For the active map or scene, in the Navigate group, click Bookmarks
and click Manage Bookmarks
to open the Bookmarks pane. The following actions are available in the Bookmarks pane:
| Action | Description |
| Create a bookmark | Interactively navigate to the desired location and scale, and click the New Bookmark button |
| Delete a bookmark | To permanently remove a bookmark from the project, hover over the bookmark and click Remove |
| Edit a bookmark description | Expand the bookmark so the description is visible. Click the Edit Description button |
| Rename a bookmark | Click a bookmark to select it. Click again to edit the name. To commit the change, either click outside of the text area or press Enter to save the update. |
| Reorganize bookmarks | Click and drag bookmarks to rearrange them in the associated map or scene groupings in the pane. You can also drag bookmarks in or out of a bookmark folder if it exists. |
| Update an existing bookmark | Navigate to the bookmark in the map and use the Explore tool |
| Pan to a bookmark | To center the view on the exact bookmark location but remain at the current map scale, use the Pan To button |
| Zoom to a bookmark | To center and zoom in on the exact bookmark location, use the Zoom To button |
| Remove time | To remove the time span captured with the bookmark, right-click the bookmark and click Remove Time |
| Remove range | To remove the range captured with the bookmark, right-click the bookmark and click Remove Range |
| Export | Click the menu button and click Export |
| Select all | Right-click a bookmark and click Select All to select all bookmarks in a single map. Selecting more than one bookmark across different maps is not supported. |
| Clear selected | Right-click a selected bookmark and click Clear Selection to clear the current selection. |
| Organize using bookmark folders | Right-click a bookmark or selected set of bookmarks and click Create Bookmark Folder |
| Zoom to a subcomponent of a bookmark | Right-click a selected bookmark and click Zoom To and open the drop-down menu for zoom options. You can zoom to individual subcomponents of a bookmark without disabling the other components. For example, zoom to only the camera perspective, only the time position, or only the range value. |
Gallery and Outline modes
The Bookmarks pane has two display modes for viewing bookmarks: Gallery and Outline. Gallery mode includes thumbnail preview images, while Outline mode is a list view without the images. Use the Menu button
in the upper right corner of the pane to switch between modes.
Manage all bookmarks for a map or scene at one time
To open the Bookmarks pane, on the Map tab, in the Navigate group, click Bookmarks
. In the Bookmarks pane, right-click the name of a map or scene to manage all associated bookmarks at once.
The following options are available when right-clicking a map or scene:
| Option | Description |
| Open Map View | Click Open Map View |
| Export All Bookmarks | Click Export All Bookmarks .bkmx) containing all bookmarks for the map including bookmarks in bookmark folders. |
| Import Bookmarks | Click Import Bookmarks .bkmx) or an ArcGIS Desktop bookmark file (.dat) into the selected map or scene. |
| Remove All Bookmarks | Click Remove All Bookmarks |
| Sort Ascending | Click Sort Ascending |
| Sort Descending | Click Sort Descending |
| Expand All Descriptions | Expand all bookmarks including those in folders so the descriptions are visible. |
| Collapse All Descriptions | Hide all bookmark descriptions by collapsing bookmarks, including those in folders, from view for the selected map or scene. |
Bookmark folders
The bookmarks pane lists bookmarks based on the map in which they are created. Within each map's list of bookmarks, you can create bookmark folders as an additional level of organization. Use a bookmark's context menu to add a folder:
Select one or more bookmarks.
Right-click a selected bookmark.
Choose Create Bookmark Folder
.The selected bookmarks will move into the new folder.
Folder names will be numbered sequentially as you continue to add more folders to each map's list of bookmarks, for example, Folder 1, Folder 2, and so on. You can move a folder by dragging it to the preferred location in the bookmark list, as well as drag bookmarks in or out of an existing folder. You cannot add multiple levels of folders in a folder.
With a bookmark folder, you can do the following using its context menu:
Rename a folder.
Export the bookmarks in the folder to a bookmark file (
.bkmx).Remove the folder which also removes the bookmarks contained in the folder.
Sort the bookmarks in the folder in ascending or descending order.
