Create bookmarks
A spatial bookmark for a map or scene identifies a geographic location (view extent and camera perspective) that you want to save and reference later. Bookmarks can also store time- and range-enabled layer properties, so you can also return to a specific point in time or a specific range value.
When you create a bookmark, it references the map or scene it was created from. The Bookmarks drop-down menu lists all of the bookmarks grouped by their associated map or scene. The active map or scene is promoted to the top for ease of access and all others are listed alphabetically by map or scene name. By default, bookmarks are listed within each in the order they were created, however, they can be rearranged using the Bookmarks pane. Create bookmarks by clicking New Bookmark from the Bookmarks drop-down menu on the Map tab, or in the Bookmarks pane.
Maps or scenes that are time or range enabled can include bookmarks with indicator icons to show additional properties. A clock icon on a bookmark thumbnail indicates a bookmark that contains time. A range slider icon indicates a bookmark that contains range.
Create a bookmark
To create a bookmark, complete the following steps:
  1. In the active map or scene, navigate to the location or perspective you want to bookmark.
  2. On the Map tab, in the Navigate group, click Bookmarks and click New Bookmark .
    If the Bookmarks pane is open, you can optionally click New Bookmark from there. Click Manage Bookmarks to open the pane.
  3. On the Create Bookmark dialog box, type a name for the bookmark and optionally type a description.
    If one or more bookmark folders exist, you can optionally pick a folder as the container of the new bookmark. By default, no folder is designated and the new bookmark will be created at the map name, or root, level.
  4. Click OK.
Bookmark descriptions
You can provide descriptive text to bookmarks to detail how and why the bookmarks were created. The description can include bold, italic, and underline formatting and hyperlinks up to a maximum of 500 characters. Check Show Descriptions if you want descriptions to appear when you view the bookmarks gallery.
Update a bookmark
To update the extent, perspective, or other properties of a bookmark, do the following:
  1. Navigate to the bookmark in the map or scene.
  2. Use the Explore tool to refine the extent or viewpoint of the bookmark.
  3. Optionally, adjust the time or range slider to update the time or range value you want to capture.
  4. Right-click the bookmark from the Bookmarks drop-down menu or hover over a bookmark in the Bookmarks pane, and click the Update button .
    The extent, time (if applicable), range (if applicable), and thumbnail of the bookmark are updated.
