Winkel I
The Winkel I is a compromise pseudocylindrical map projection for world maps. It is an arithmetic mean of projected coordinates of sinusoidal and equidistant cylindrical projections and a general case of the Eckert V projection. The meridians are sinusoidal curves, producing undesirable bulging along the equator on the west and east edges of the map.
The projection was introduced by Oswald Winkel in 1914. In his original design, Winkel used a standard parallel at 50°28ʹ. It is available in ArcGIS Pro 1.0 and later and in ArcGIS Desktop 8.0 and later.
Projection properties
The subsections below describe the Winkel I projection properties.
Graticule
Winkel I is a pseudocylindric projection. The equator and the central meridian are projected as straight lines. The other meridians are sinusoidal curves, bulging away the central meridian and equally spaced. The parallels are equally distributed straight lines perpendicular to the central meridian. The poles project as straight lines. The lengths of the central meridian and both pole lines depend on the value of the standard parallel. The graticule is always symmetric across the equator and the central meridian.
Distortion
The Winkel I projection is neither conformal nor equal-area. It generally distorts shapes, areas, distances, directions, and angles. The scale is constant along any given parallel and it is true along the standard parallel. The high latitude areas are exaggerated. Bulging meridians produce considerable distortion toward the edges of the projection. The distortion values are symmetric across the equator and the central meridian.
Usage
Winkel I projection is appropriate for general world maps although its use is not advisable.
Limitations
Winkel I is supported on spheres only. For an ellipsoid, the semimajor axis is used for the radius.
Parameters
Winkel I parameters are as follows:
False Easting
False Northing
Central Meridian
Standard Parallel 1
Particular parameter cases
When the standard parallel is set at the equator, the result is the Eckert V map projection.
Sources
