Complex scenarios for route calibration
Available with Location Referencing license.
The following are scenarios for route calibration of complex routes that include loop, branch, lollipop, and alpha routes.
Calibration on a loop route
In the following example, a calibration point is added in the middle of a loop route (RouteX) using a different measure (2.5) than the existing measure (2), but no downstream measures are affected since Recalibrate route downstream is unchecked:
A calibration point is added using the new measure (2.5).
Calibration on a branch route
In the following example, a calibration point is added on a branch route (RouteX) using a different measure (2) than the existing measure (4.5), but no downstream measures are affected since Recalibrate route downstream is unchecked:
A calibration point is added using the updated measure (2). All downstream measures remain the same.
Calibration on a lollipop route
In the following example, an existing calibration point (0) at the beginning of a lollipop route (RouteX) is updated using a new measure (2), but no downstream measures are affected since Recalibrate route downstream is unchecked:
The calibration point is updated using the new measure (2). All downstream measures remain the same.
Calibration on an alpha route
In the following example, an existing calibration point (2.33) on an alpha route (RouteX) is updated using a new measure (3), but no downstream measures are affected since Recalibrate route downstream is unchecked:
The calibration point is updated using the new measure (3). All downstream measures remain the same.
