Delete calibration points
Available with Location Referencing license.
The calibration points used by ArcGIS Pipeline Referencing are stored in a feature class. Calibration points on a route can be deleted by doing one of the following:
  • Use the Delete Point tool on the Location Referencing tab.
  • Use the Delete button in the Features group on the Edit tab.
  • Use the attribute selection in the calibration point feature layer's attribute table.
Caution:
Before deleting a calibration point, consider whether retiring the point is more appropriate. Retiring a calibration point preserves the historical integrity and calibration of the route. Deleting a calibration point results in recalibration of the route for the time span that the calibration point was active. To retire a calibration point, use the Edit tool to change the To Date value of the calibration point.
Learn more about modifying calibration points
Calibration point deletion scenario
The following examples illustrate the three steps of deletion and recalibration using the Delete tool .
Deleting a calibration point results in recalibration of the route to the nearest upstream and downstream calibration point.
First, review the calibration points and route calibration and identify a calibration point to delete. In this example, 8 is identified for deletion.
Calibration point before deletion
Then, delete the calibration point with a measure of 8.
Deleting a calibration point diagram with existing calibration point deleted
Calibration is only updated to the nearest upstream and downstream calibration points on the route.
Delete using the Delete Point tool
To delete calibration points using the Delete tool, complete the following steps:
  1. On the Location Referencing tab, in the Calibration Points group, click the Delete Point tool .
    Branch versioned networks, including any network configured with a user-generated route ID, must be edited through a feature service.
  2. Select the calibration point you want to delete on the map.
    The Delete Calibration Point pane appears with attributes for the selected calibration point populated.
    The fields in the Delete Calibration Point pane are read-only.
  3. Click Run.
    The calibration point is deleted, and the route is recalibrated between the nearest upstream and downstream calibration points. A message appears in the Delete Calibration Point pane indicating that the point was successfully deleted.
  4. If more calibration points are ready to be deleted, repeat the steps above to delete them.
    If a message regarding acquiring locks or reconciling appears, conflict prevention is enabled.
    After a route is selected, the tool will attempt to release the route lock if the route lock is acquired by the active user in a different version and its releasable status value is Yes.
Delete a calibration point using delete features
To delete one or more calibration points using the Delete tool, complete the following steps:
  1. Add the LRS feature layers, including the calibration point and network feature layers, to a map.
    Alternatively, open a map in which the LRS feature layers are present.
  2. Zoom in to the calibration point that you want to delete.
  3. Optionally, on the Location Referencing tab, in the Calibration Points group, click the Event Behavior drop-down arrow and include or exclude event behaviors for manual calibration edits.
    • Exclude event behaviors for manual calibration edits Exclude Event Behaviors—Ignore event behavior in subsequent manual edits.
    • Include event behaviors for manual calibration edits Include Event Behaviors—Include event behavior in subsequent manual edits.
  4. Click the calibration point that you want to delete.
    Select multiple calibration points on the map to delete them all at once; then perform the remaining steps in this workflow. You can also delete calibration points in bulk by selecting them from the attributes table of the calibration point feature layer.
  5. On the Edit tab, in the Features group, click Delete .
    The Deleting selected feature progress dialog box appears and the selected calibration point is deleted.
  6. On the Edit tab, in the Manage Edits group, click Save Edits .
