Configure event replacement
Available with Location Referencing license.
When performing pipeline maintenance, sometimes a section of a pipe is taken out of the ground and is replaced by a new pipe. This process is known as pipe replacement.
During pipe replacement, events on an edited section of a route can be left as is, retired, or retired and replaced according to an event replacement configuration.
Event layers must be categorized on the Configure Replace Events dialog box before event replacement. The measures for the route do not change during event replacement.
Event replacement scenario
The configuration of event replacement requires categorizing the events in the feature service into three categories: As Is, Retire, and Retire and Replace.
Tip:
Point events can only be categorized using Retire.
Before event replacement
The following diagram illustrates a pipeline section before replacement:
Before replacement, the pipe section has eight events: three point events (events 1-3) and five linear events (events 4-8).
Table 1: Event table before replacement
Event layer |
Event ID |
From Measure |
To Measure |
Value |
From Date |
To Date |
Event 1 |
1A |
1 |
N/A |
GGG |
1/1/2000 |
Null |
Event 2 |
2A |
2 |
N/A |
SSS |
1/1/2000 |
Null |
Event 3 |
3A |
3 |
N/A |
HHH |
1/1/2000 |
Null |
Event 4 |
4A |
0 |
10 |
XXX |
1/1/2000 |
Null |
Event 5 |
5A |
0 |
10 |
YYY |
1/1/2000 |
Null |
Event 6 |
6A |
0 |
10 |
ZZZ |
1/1/2000 |
Null |
Event 7 |
7A |
0 |
10 |
QQQ |
1/1/2000 |
Null |
Event 8 |
8A |
0 |
10 |
WWW |
1/1/2000 |
Null |
A pipe with measures from 0 to 10 exists. Various line and point events are present in the pipe as shown above.
During inspection, it was determined that a section of the pipe between the measures 0 and 5 needs to be replaced on 12/31/2017, as shown below.
The events are placed in the following event replacement categories:
Table 2: Event replacement categories
Retire |
Retire and replace |
Keep as is |
Event 2 |
Event 5 |
Event 1 |
Event 3 |
Event 8 |
Event 7 |
Event 4 |
Event 6 |
After event replacement
The results of replacing the pipe and events are shown in the following diagram and in Table 3:
Table 3: After event replacement
Event layer |
Event ID |
From Measure |
To Measure |
Value |
From Date |
To Date |
Case |
Event 1 |
1A |
1 |
GGG |
1/1/2000 |
Null |
A |
Event 2 |
2A |
2 |
SSS |
1/1/2000 |
12/31/2017 |
B |
Event 3 |
3A |
3 |
HHH |
1/1/2000 |
12/31/2017 |
C |
Event 4 |
4A |
0 |
10 |
XXX |
1/1/2000 |
12/31/2017 |
D |
Event 4 |
4B |
5 |
10 |
XXX |
12/31/2017 |
Null |
E |
Event 5 |
5A |
0 |
10 |
YYY |
1/1/2000 |
12/31/2017 |
F |
Event 5 |
5B |
5 |
10 |
YYY |
12/31/2017 |
Null |
G |
Event 5 |
5C |
0 |
5 |
YYYOO |
12/31/2017 |
Null |
H |
Event 6 |
6A |
0 |
10 |
ZZZ |
1/1/2000 |
12/31/2017 |
I |
Event 6 |
6B |
5 |
10 |
ZZZ |
12/31/2017 |
Null |
J |
Event 7 |
7A |
0 |
10 |
QQQ |
1/1/2000 |
Null |
K |
Event 8 |
8A |
0 |
10 |
WWW |
1/1/2000 |
12/31/2017 |
L |
Event 8 |
8B |
5 |
10 |
WWW |
12/31/2017 |
Null |
M |
Event 8 |
8C |
0 |
5 |
WWWOO |
12/31/2017 |
Null |
N |
Table 4: Explanation of event replacement
Case |
Event layer |
Explanation |
A |
Event 1 |
The event is left as is. |
B |
Event 2 |
The event is retired because it was in the Retire category. |
C |
Event 3 |
D |
Event 4 |
The whole event is retired because it was in the Retire category. |
E |
Event 4 |
A new event is created for the existing section of the pipe, keeping the attribute values of the original event. |
F |
Event 5 |
The entire event is retired because it was in the Retire and Replace category. |
G |
Event 5 |
H |
Event 5 |
A new event is created for the new section of the pipe with the new dates and attributes provided in the Replace Events pane. |
I |
Event 6 |
The entire event is retired because it was in the Retire category. |
J |
Event 6 |
K |
Event 7 |
L |
Event 8 |
M |
Event 8 |
N |
Event 8 |
Categorize events
To configure event replacement, complete the following steps :
In ArcGIS Pro, open the map that contains the feature service in which events will be retired or replaced.
On the Location Referencing tab, in the Events group, click Configure Replacement
.The Configure Replace Events dialog box appears.
If no event replacement configuration exists, the Create New Replace Events dialog box appears on top of the Configure Replace Events dialog box where you can create a named configuration.
Tip:
All the line events
and point events
available in the feature service are listed in the Event Layers list.
Press the Shift key and click to select a range of events, or press the Ctrl key and click to select events out of order; then drag multiple line events from the Event Layers list to the Retire Events list.
You can also use the arrow buttons on the dialog box to move selected layers between the Event Layers list and other lists or to move line event layers up and down between the Retire Events and Retire and Replace Events lists.
Tip:
Click Reset to set the configuration to its original or last saved state.
Event layers that remain in the Event Layers list are left as is when event replacement is run.
Press the Shift key and click to select a range of events, or press the Ctrl key and click to select events out of order; then drag multiple line events from the Event Layers list to the Retire and Replace Events list.
Only line events
can be retired and replaced.
If no events are configured for retirement or for retirement and replacement, it is not possible to save the configuration.
Optionally, click the expand button for any event layer in the Retire and Replace Events list to expand it.
An expanded list of editable event layer fields appears. Uncheck a check box to exclude it from event replacement.
If default attributes are configured, they are listed. Default attributes can be overwritten when using the Replace Events pane for event replacement.
Some attribute fields are required attribute fields
. A required attribute field is a nonnullable field with no default value. The check box for a required attribute field cannot be unchecked.Click Save to save the event replacement configuration.
The event replacement configuration is saved to the replace events folder location, which is the same location as the active ArcGIS Pro project folder by default.
You can specify an alternate replace events folder location in the Location Referencing options in ArcGIS Pro.
If an event replacement configuration file (
.lrer) with the specified name doesn’t already exist, it is created using the name provided on the Create New Replace Events dialog box.Optionally, click Save As to save the configuration to an
.lrerfile using a different name or location.You can share the saved
.lrerfile so that others can place it in the replace events folder location.To remove an existing event replacement configuration, delete the
.lrerfile from the replace events folder location.Optionally, click Set As Default to set this event replacement configuration as the default for the project.
Click Close
to close the Configure Replace Events dialog box.
