Form a new route method
Available with Location Referencing license.
During route reassignment, events are impacted in the edit section and upstream and downstream of the reassignment, depending on the configured event behavior for the event layer.
Events are not updated until the Apply Event Behaviors tool is run after route edits. If you are using conflict prevention on branch versioned data, you are prompted to run Apply Event Behaviors before posting to the default version.
When Recalibrate route downstream is chosen for an LRS route edit, the configured calibrate event behavior is applied to downstream sections. You can review configured event behaviors by viewing LRS event properties.
The reassignment method, route edit, and event behaviors are described below.
A new route is created by merging source routes if multiple routes are selected in the source.
A new route is created by splitting source route if a partial route is selected in the source.
Route is renamed by selecting an entire route and providing a new route name or ID.
Upstream and downstream sections
Route editing impacts upstream and downstream sections differently.
The following image shows the upstream and downstream section for the route reassignment scenario:
The following table details how the reassignment editing activity impacts upstream and downstream events according to the configured event behavior:
Behavior |
Events upstream reassignment |
Events intersecting reassignment |
Events downstream reassignment |
Stay Put |
No action |
Retire event. Line events crossing the edit section are split and the original event is retired. |
If route calibration is changed, the calibrate event behavior is applied; otherwise, no action is taken. |
Move |
Shape regenerated, if needed, to new location of route measures |
Shape regenerated to the new location of route measures. |
Retire |
No action |
Retire event. Line events crossing the reassignment region do not split. |
Snap |
No action |
Geographic location (x,y) is maintained. The event is migrated to the reassigned route. Line events crossing the edit section are split. |
The network can contain events that span routes in a line network. The behaviors are still applied in the same manner.
Because the LRS is time aware, routes and events are time sliced with edit activities, such as reassigning a route.
The following sections detail two capabilities in the Form a new route method: splitting and renaming. Additional capabilities, such as merging, work similarly to the Merge to adjacent route method.
Form a new route by splitting an existing route
In this example, the routes are active from 1/1/2000. Reassignment is set to occur on 1/1/2005, where the second half of Route1 splits out and forms a new route in 2005. The graphics and tables below demonstrate the route information before and after the reassignment.
Before route reassignment
The following image shows the routes before reassignment:
The following table provides details about the routes before reassignment:
Route Name |
From Date |
To Date |
From Measure |
To Measure |
Route1 |
1/1/2000 |
<Null> |
0 |
10 |
After route reassignment
The following image shows the routes after reassignment:
The following table provides details about the routes after reassignment:
Route Name |
From Date |
To Date |
From Measure |
To Measure |
Route1 |
1/1/2000 |
1/1/2005 |
0 |
10 |
Route1 |
1/1/2005 |
<Null> |
0 |
5 |
RouteNew |
1/1/2005 |
<Null> |
0 |
5 |
Events before reassignment
The following image shows the routes and events before reassignment:
The following table provides details about the events before reassignment:
Event |
Route Name |
From Date |
To Date |
From Measure |
To Measure |
Event1 |
Route1 |
1/1/2000 |
<Null> |
0 |
7 |
Event2 |
Route1 |
1/1/2000 |
<Null> |
7 |
10 |
The following sections detail how event behavior rules are enforced after running the Apply Event Behaviors tool, when a new route is created by splitting from the source route.
Stay Put event behavior
Although the geographic location of the event outside the reassign region is maintained, the measures can change. The event can also split if it crosses the reassign region. Portions in the reassign region are retired.
The route reassignment described above has the following effects:
Event1 was partially in the edit section. It is retired on the date of reassignment, and a new event is created on the nonimpacted portion with the reassignment date as the From Date. The To Measure is changed to accommodate the new ending measure 5 of Route1.
Event2 is retired on the date of reassignment because it fell entirely within the edit section.
The following image shows the routes and events after reassignment:
It is important to note that retired events are not drawn in the graphic above.
The following table provides details about the events after reassignment when Stay Put is the configured event behavior:
Event |
Route Name |
From Date |
To Date |
From Measure |
To Measure |
Loc Error |
Event1 |
Route1 |
1/1/2000 |
1/1/2005 |
0 |
7 |
No Error |
Event1 |
Route1 |
1/1/2005 |
<Null> |
0 |
5 |
No Error |
Event2 |
Route1 |
1/1/2000 |
1/1/2005 |
7 |
10 |
No Error |
Move event behavior
Although the measures of the event are maintained, the geographic location can change.
Event1 was partially in the edit section. It is retired on the date of reassignment, and a new event with the reassignment date as the From Date is created on the nonimpacted portion. Because the measures do not change for the Move behavior, there is a location error for the To Measure because that measure 7 no longer exists on Route1.
Event2 is retired on the date of reassignment since it fell within the edit section. From the date of reassignment, a new event is created. Because the measures remain same, the newly produced event receives the location error because both its From and To measures cannot be found on Route1.
The following table provides details about the events after reassignment when Move is the configured event behavior:
Event |
Route Name |
From Date |
To Date |
From Measure |
To Measure |
Location Error |
Event1 |
Route1 |
1/1/2000 |
1/1/2005 |
0 |
7 |
No Error |
Event2 |
Route1 |
1/1/2000 |
1/1/2005 |
7 |
10 |
No Error |
Event1 |
Route1 |
1/1/2005 |
<Null> |
0 |
7 |
Partial Match for the To Measure |
Event2 |
Route1 |
1/1/2005 |
<Null> |
7 |
10 |
Measure Extent Out of Route Measure Range |
The new Event2 exists after the Apply Event Behaviors tool is run but has no shape.
Retire event behavior
Events intersecting the reassignment region are retired.
Event1 was present in the edit section; it is retired on the date of reassignment.
Event2 was present in the edit section; it is retired on the date of reassignment.
The following table provides details about the events after reassignment when Retire is the configured event behavior:
Event |
Route Name |
From Date |
To Date |
From Measure |
To Measure |
Loc Error |
Event1 |
Route1 |
1/1/2000 |
1/1/2005 |
0 |
7 |
No Error |
Event2 |
Route1 |
1/1/2000 |
1/1/2005 |
7 |
10 |
No Error |
Snap event behavior
Although the geographic location of the event is maintained by snapping to the route that it was reassigned to, the measures can change. The event can also split if it crosses the reassign region.
Event1 was partially in the edit section. It is retired on the date of reassignment, and a new event with the reassignment date as the From Date is created on the nonimpacted portion of Route1.
Part of Event1 that was in the impacted portion is snapped to the new route with the new measures underlying on RouteNew. It gets its From Date from the date of reassignment.
Event2 is retired on the date of reassignment since it fell within the edit section. From the date of reassignment, a new event is created snapped to the new route with the new measures underlying on RouteNew. It gets its From Date from the date of reassignment.
The following table provides details about the events after reassignment when Snap is the configured event behavior:
Event |
Route Name |
From Date |
To Date |
From Measure |
To Measure |
Location Error |
Event1 |
Route1 |
1/1/2000 |
1/1/2005 |
0 |
7 |
No Error |
Event1 |
Route1 |
1/1/2005 |
<Null> |
0 |
5 |
No Error |
Event1 |
RouteNew |
1/1/2005 |
<Null> |
0 |
2 |
No Error |
Event2 |
Route1 |
1/1/2000 |
1/1/2005 |
7 |
10 |
No Error |
Event2 |
RouteNew |
1/1/2005 |
<Null> |
2 |
5 |
No Error |
Form a new route by renaming an existing route
In this example, the routes are active from 1/1/2000 Reassignment is set to occur on 1/1/2005, where Route1 is renamed to RouteNew while maintaining its measures in 2005. The graphics and tables below demonstrate the route information before and after the reassignment.
Route Name |
From Date |
To Date |
From Measure |
To Measure |
Route1 |
1/1/2000 |
<Null> |
0 |
10 |
Route Name |
From Date |
To Date |
From Measure |
To Measure |
Route1 |
1/1/2000 |
1/1/2005 |
0 |
10 |
RouteNew |
1/1/2005 |
<Null> |
0 |
10 |
Event |
Route Name |
From Date |
To Date |
From Measure |
To Measure |
Event1 |
Route1 |
1/1/2000 |
<Null> |
0 |
7 |
Event2 |
Route1 |
1/1/2000 |
<Null> |
7 |
10 |
The following sections detail how event behavior rules are enforced after running the Apply Event Behaviors tool, when a new route is created by renaming a source route.
Since the entire route Route1 is reassigned to RouteNew, both the events retire.
Event1 was entirely in the edit section; it is retired on the date of reassignment.
Event2 was entirely in the edit section; it is retired on the date of reassignment.
Event |
Route Name |
From Date |
To Date |
From Measure |
To Measure |
Event1 |
Route1 |
1/1/2000 |
1/1/2005 |
0 |
7 |
Event2 |
Route1 |
1/1/2000 |
1/1/2005 |
7 |
10 |
Move event behavior
The route renaming scenario described above has the following effects:
Event1 was entirely in the edit section. It is retired on the date of reassignment, and a new event with the reassignment date as the From Date is created. A location error is generated for the new event as the original route Route1 does not exist from 1/1/2005 as a new route RouteNew has taken its place, although the measures remain the same.
Event2 was entirely in the edit section. It is retired on the date of reassignment, and a new event with the reassignment date as the From Date is created. A location error is generated for the new event as the original route Route1 does not exist from 1/1/2005 as a new route RouteNew has taken its place, although the measures remain the same.
Event |
Route Name |
From Date |
To Date |
From Measure |
To Measure |
Location Error |
Event1 |
Route1 |
1/1/2000 |
1/1/2005 |
0 |
7 |
No Error |
Event2 |
Route1 |
1/1/2000 |
1/1/2005 |
7 |
10 |
No Error |
Event1 |
Route1 |
1/1/2005 |
<Null> |
0 |
7 |
Route not Found |
Event2 |
Route1 |
1/1/2005 |
<Null> |
7 |
10 |
Route not Found |
The new Event1 and Event2 exist after the Apply Event Behaviors tool is run but have no shape.
Events intersecting the reassignment region are retired. Since the entire route Route1 is reassigned to RouteNew, both the events retire.
Event |
Route Name |
From Date |
To Date |
From Measure |
To Measure |
Event1 |
Route1 |
1/1/2000 |
1/1/2005 |
0 |
7 |
Event2 |
Route1 |
1/1/2000 |
1/1/2005 |
7 |
10 |
Snap event behavior
Event1 was entirely in the edit section; it is retired on the date of reassignment, and a new event with the reassignment date as the From Date is created on the new route with the new measures underlying on RouteNew. The geographic location of the event is maintained.
Event |
Route Name |
From Date |
To Date |
From Measure |
To Measure |
Location Error |
Event1 |
Route1 |
1/1/2000 |
1/1/2005 |
0 |
7 |
No Error |
Event1 |
RouteNew |
1/1/2005 |
<Null> |
0 |
7 |
No Error |
Event2 |
Route1 |
1/1/2000 |
1/1/2005 |
7 |
10 |
No Error |
Event2 |
RouteNew |
1/1/2005 |
<Null> |
7 |
10 |
No Error |
Detailed behavior results on routes in a line network with events that span routes
In this example, there are four routes on the same line, and the routes are active from 1/1/2000. On 1/1/2005, three separate reassignments are set to occur.
The first reassignment merges Route1 and Route2 into a new route, RouteM.
The second reassignment splits Route3 at measure 28 and creates a new route called RouteS out of the original measure 28 to 35 on Route3 with target values of 0 to 20.
The third reassignment renames Route4 to RouteR and maintains Route4's original measures.
Route Name |
Line Name |
Line Order |
From Date |
To Date |
From Measure |
To Measure |
Route1 |
LineA |
100 |
1/1/2000 |
<Null> |
0 |
10 |
Route2 |
LineA |
200 |
1/1/2000 |
<Null> |
12 |
22 |
Route3 |
LineA |
300 |
1/1/2000 |
<Null> |
25 |
35 |
Route4 |
LineA |
400 |
1/1/2000 |
<Null> |
38 |
48 |
Route Name |
Line Name |
Line Order |
From Date |
To Date |
From Measure |
To Measure |
Route1 |
LineA |
100 |
1/1/2000 |
1/1/2005 |
0 |
10 |
Route2 |
LineA |
200 |
1/1/2000 |
1/1/2005 |
12 |
22 |
RouteM |
LineA |
100 |
1/1/2005 |
<Null> |
0 |
20 |
Route3 |
LineA |
300 |
1/1/2000 |
1/1/2005 |
25 |
35 |
Route3 |
LineA |
200 |
1/1/2005 |
<Null> |
25 |
28 |
RouteS |
LineA |
300 |
1/1/2005 |
<Null> |
0 |
20 |
Route4 |
LineA |
400 |
1/1/2000 |
1/1/2005 |
38 |
48 |
RouteR |
LineA |
400 |
1/1/2005 |
<Null> |
38 |
48 |
The following image shows the routes and event before reassignment:
The following table provides details about the spanning event before reassignment:
Event ID |
From Date |
To Date |
From Route Name |
To Route Name |
From Measure |
To Measure |
Event1 |
1/1/2000 |
<Null> |
Route1 |
Route4 |
0 |
48 |
The following sections detail how event behavior rules are enforced when routes on a line in a line network are reassigned.
Stay Put behavior
After the three separate reassignments described above, Event1 falls in the edit section. It is retired on the date of reassignment, and a new event with the reassignment date as the From Date is created. The new event is located only on part of the Route3 that was not impacted by the three edits.
The following image shows the routes and event after reassignment:
It is important to note that the retired event is not drawn in the graphic above.
The following table provides details about the event after reassignment when Stay Put is the configured event behavior:
Event |
From Route Name |
To Route Name |
From Date |
To Date |
From Measure |
To Measure |
Loc Error |
Event1 |
Route1 |
Route4 |
1/1/2000 |
1/1/2005 |
0 |
48 |
No Error |
Event1 |
Route3 |
Route3 |
1/1/2005 |
<Null> |
25 |
28 |
No Error |
Move behavior
After the three separate reassignments described above, Event1 was partially in the edit section. It is retired on the date of reassignment, and a new event with the reassignment date as the From Date is created. The move behavior does not allow changing the From and To route IDs or measures of the event. It returns a location error because both the From and To routes (Route1 and Route4) do not exist as of 1/1/2005.
The following table provides details about the event after reassignment when Move is the configured event behavior:
Event ID |
From Date |
To Date |
From Route Name |
To Route Name |
From Measure |
To Measure |
Location Error |
Event1 |
1/1/2000 |
1/1/2005 |
Route1 |
Route4 |
0 |
48 |
No Error |
Event1 |
1/1/2005 |
<Null> |
Route1 |
Route4 |
0 |
48 |
Route not Found |
The new Event1 exists after the Apply Event Behaviors tool is run but has no shape.
Retire behavior
After the three separate reassignments described above, Event1 was present in the edit section. It is retired on the date of reassignment.
The following table provides details about the event after reassignment when Retire is the configured event behavior:
Event |
From Route Name |
To Route Name |
From Date |
To Date |
From Measure |
To Measure |
Loc Error |
Event1 |
Route1 |
Route4 |
1/1/2000 |
1/1/2005 |
0 |
48 |
No Error |
Snap event behavior
After the three separate reassignments described above, Event1 was present in the edit section. It is retired on the date of reassignment, and a new event with the reassignment date as the From Date is created on the new routes with the new underlying measures to maintain its geographic location.
The following table provides details about the event after reassignment when Snap is the configured event behavior:
Event |
From Date |
To Date |
From Route Name |
To Route Name |
From Measure |
To Measure |
Location Error |
Event1 |
1/1/2000 |
1/1/2005 |
Route1 |
Route4 |
0 |
48 |
No Error |
Event1 |
1/1/2005 |
<Null> |
RouteM |
RouteR |
0 |
48 |
No Error |
